Here my auto eq setting, more midrange with less of a cut(reducing band level)with less band effect.
Give it a try and see what you think
Couldn't upload file
so use notepad & insert
[Spectrum Correction]
Abrupt change protection=1
Abrupt change protection - Reduce effect=1
Adjust time=1220
Center frequency band 1=99.633735657
Center frequency band 2=399.86605835
Center frequency band 3=864
Center frequency band 4=3700.010498047
Center frequency band 5=6200.162109375
Center frequency band 6=11800
Center frequency band 7=12084.856445313
Center frequency band 8=13930.2265625
Center frequency band 9=17200
Channel linking band 1=0
Channel linking band 2=0
Channel linking band 3=0
Channel linking band 4=0
Channel linking band 5=0
Channel linking band 6=99
Channel linking band 7=99
Channel linking band 8=99
Channel linking band 9=99
Effect strength band 1=0.400000006
Effect strength band 2=0.400000006
Effect strength band 3=0.400000006
Effect strength band 4=0.400000006
Effect strength band 5=0.400000006
Effect strength band 6=0.5
Effect strength band 7=0.5
Effect strength band 8=0.5
Effect strength band 9=0.5
Enabled=1
Flat band tops=1
Flat band tops value band 1=0.699999988
Flat band tops value band 2=0.699999988
Flat band tops value band 3=0.699999988
Flat band tops value band 4=0.699999988
Flat band tops value band 5=0.680000007
Flat band tops value band 6=0.699999988
Flat band tops value band 7=0.699999988
Flat band tops value band 8=0.699999988
Flat band tops value band 9=0.699999988
Flat frequency response=0
Flat frequency response new=0
Hear=0
Hide median=1
ITU-BS.1770 band 1=0
ITU-BS.1770 band 2=0
ITU-BS.1770 band 3=0
ITU-BS.1770 band 4=0
ITU-BS.1770 band 5=0
ITU-BS.1770 band 6=0
ITU-BS.1770 band 7=0
ITU-BS.1770 band 8=0
ITU-BS.1770 band 9=0
Max boost band 1=6
Max boost band 2=6
Max boost band 3=6
Max boost band 4=6
Max boost band 5=3
Max boost band 6=8
Max boost band 7=8
Max boost band 8=8
Max boost band 9=8
Max cut band 1=-0.699999988
Max cut band 2=-0.5
Max cut band 3=-0.5
Max cut band 4=-1
Max cut band 5=-2
Max cut band 6=-2.5
Max cut band 7=-4
Max cut band 8=-4
Max cut band 9=-4
Number of bands=5
Output Level band 1=1
Output Level band 2=1
Output Level band 3=1
Output Level band 4=1
Output Level band 5=1
Output Level band 6=1
Output Level band 7=1
Output Level band 8=1
Output Level band 9=1
Relative kick time=0.150000006
Relative target band 1=33138.1875
Relative target band 2=32768
Relative target band 3=28026.580078125
Relative target band 4=16643.783203125
Relative target band 5=8520
Relative target band 6=8192
Relative target band 7=8192
Relative target band 8=8192
Relative target band 9=8192
Steepness left band 2=12
Steepness left band 3=12
Steepness left band 4=12
Steepness left band 5=12
Steepness left band 6=12
Steepness left band 7=12
Steepness left band 8=12
Steepness left band 9=12
Steepness right band 1=12
Steepness right band 2=12
Steepness right band 3=12
Steepness right band 4=12
Steepness right band 5=12
Steepness right band 6=12
Steepness right band 7=12
Steepness right band 8=12
Save text as _.sts
