 Post subject: Stereo Tool 8.51
PostPosted: Fri Sep 15, 2017 12:55 am
Stereo Tool 8.51 (SEPTEMBER 13th 2017)
:!: - Version 8.50 did not run properly in Windows XP, due to a Microsoft Visual Studio 2015 bug. Workaround added.
:!: - Top (presets) part of Stereo Tool web interface could still get in a reload loop - fixed.
:!: - Memory usage slightly reduced.
:!: - SST interface colors updated.
:!: - MicroMPX now supports multiple sample rates.
https://www.stereotool.com/download/
 Post subject: Re: Stereo Tool 8.51
PostPosted: Fri Sep 15, 2017 3:50 pm
Standalone v8.51 Release x32 & x64
Just tried the "Sound cards>self tests" option for the first time today. Love the sound effects when you click on "Send self test audio". :D
But, when I click on "Check self test audio" it locks up the ST program and won't let you close it, so I have to use task manager to end it. :o
I tried typing a path into the "output file path" box, but nothing happens and without any help tips for this, I'm not sure I am using it correctly. :roll:
PostPosted: Sat Sep 16, 2017 1:27 am
If it locks up something must be broken. I haven't used it in a while so it might be....
How to use it, if it works:
- In the Stereo Tool instance that performs the check, type in a path to log to
- Make sure that the instance that performs the check sees the signal from the sending instance, and that both are set to 192 (or 176.4) kHz
- In the receiving instance, enable Check
- In the sending instance, enable Send
This will take a few minutes. Once the test is done the output file is written with analysis data.
Note: The sending and receiving instance can be the same!
PostPosted: Sat Sep 16, 2017 9:43 am
I confirm there is a hang up
When i click the "Bands" in Auto EQ ... then GUI is freezing but sound is still playing.
PostPosted: Sat Sep 16, 2017 12:22 pm
Please test this track with this preset (if possible listen from FM out or Normal output)
Is there any voice vibration in the first 30 seconds of the track? I listen it without processing and don`t hear this.
My guess is: it cames from new features ...
http://www100.zippyshare.com/v/mLh17nmq/file.html
PostPosted: Sun Sep 17, 2017 8:23 am
DJ, I am not hearing any issues testing here with Breaking Dreams latest profile..
Can you please explain further exactly what your hearing as a issue?
PostPosted: Sun Sep 17, 2017 8:43 am
If you don`t see, i clearly write to test with the preset included in the archive.
In the voice, there is vibration when the bass goes to certain frequency or level.
And because i don`t hear this in older version (without new features), i guess this is from them.
PostPosted: Sun Sep 17, 2017 9:42 pm
I clearly hearing that vibration :shock: :o
PostPosted: Wed Sep 27, 2017 11:56 am
Ok I just checked and I also hear it in version 8.40 if I load this preset. Maybe slightly less (probably because the high frequencies are at a lower level). The amount of IMD relative to the audio level is not lower though.
Try this:
In the Clipper settings, under "Distortion",
- Enable 'Reduce asymmetric bass'. That helps with the "For him".
- Enable 'Reduce IMD voice vibrations' - that's made specifically to fix this type of issue!
This definitely makes it better.
If you want to fine-tune it more, tweak the bass filter frequencies (currently 80 and 200 Hz). I don't have time to look into this further right now....
PostPosted: Thu Sep 28, 2017 12:01 am
Preset is cataclysm. From it i can expect everything bad.
