PostPosted: Wed May 05, 2010 6:29 am
I am using Stereo Tool with SAM Broadcaster.
I just installed the new 5.00 version - before now I was running the 4.22 version.
I haven't tested this in the new version, but I assume this didn't change.
When I start SAM up, if t was off before, Stereo Tool doesn't load my last preset automatically.
Is there any way to have it automatically open the last preset that was used, so I don't have to reload it every time?
Thanks!
PostPosted: Wed May 05, 2010 9:03 am
Thanks!
That's odd - it should always open with the settings that were active when you closed it. (The _name_ of the preset isn't shown in the drop-down menu, but the settings should be there).
If they are not: Which OS are you using?
PostPosted: Wed May 05, 2010 9:05 am
I was assuming that if it didn't show the preset name, it wasn't loaded...
So maybe it is in face loading the settings correctly.
I'm going to go back and check.
And that computer is running Windows XP Pro SP3.
Thanks!
