 Post subject: Aussie - Rattling Dreams
PostPosted: Fri Aug 18, 2017 12:51 pm
ST Type: Winamp
ST Version: 8.41 Beta 047
ST Licence: Pro (Everything) + new Advanced Dynamics
ST Profile: ST_841B047_v1a - Aussie - Rattling Dreams (~8dBr).sts
ST Dest: FM Output
Typical Top 40 Short LKFS: -6
Profile Use: Top 40, Rock, Dance, Trance, LPON
Comments:
Yet further fine tuning pushing bass and much wider airier sound to reduce bass fatigue. Loudness upto ~8.5dBr with Top 40 for FM use.
As before, can be used an full anger on air for sound testing and take full use of the new Advanced Dynamics.
If using in a live situation, you need to import in parts.
1. Reset All Configuration settings, and then import All Configuration settings from the file
2. Reset All Processing settings, and then import All Processing settings from the file.
3. Click on Limiting & Clipping, Reset All Limiting & Clipping, and then import all Limiting & Clipping settings from the file.
4. Carefully manually check the Limiting & Clipping settings, especially in the Advanced Clipper. I found the Composite Strictness and True Peak dont import correctly. These are set to 10 in the profile.
Oh, dont forget to purchase the new feature licence.
Have fun!
PostPosted: Fri Aug 25, 2017 2:01 pm
Profile Update
ST Type: Standalone
ST Version: 8.41 Beta 050
ST Profile: ST_841B050_v1a - Aussie - Rattling Dreams (~8dBr).sts
ST Dest: FM Output or Stream
Typical Top 40 Short LKFS: -7
- Restored Stereo Imaging settings
- Increased output drives and clipper slightly
- Stokkemask enabled
PostPosted: Sun Nov 19, 2017 12:33 pm
Profile Update
ST Type: Standalone
ST Version: 8.54 Beta 011
ST Licence: Pro (Everything) + new Auto EQ
ST Profile: ST_854_v1 - Rattling Dreams (~8dBr).sts
- Changed bandwidth 30-20K default, FM out to 16k
- Changed Normal Out to thread.
- Disabled Stokkemask
ST_854_v1 - Rattling Dreams (~8dBr).sts [108.25 KiB]
Downloaded 537 times
