First off, the reason I'm using Stereo Tool is to undo CSG processing on '60s recordings. The only function I need (for that, anyway) is the Phase Angle slider - either -90 degrees or 90 degrees. I don't want anything else in the chain, and the resulting file should *only* be different with regards to that phase change, and only in the right channel. The left channel shouldn't be touched.
While experimenting with both the command line versions (3.55 and 4.22) and the Winamp plug-in versions (4.22 and 5 beta 2) I've noticed that even if I have everything off, the audio is still being modified. It shouldn't be. It should be an exact copy of what is fed in.
While playing with the Compare WAVs function in EAC, I've noticed the following:
- 3.55 and 4.22 give identical results on the command line
- 3.55/4.22 generate files that have some unchanged samples and some changed samples
- loading the settings into the 5b2 Winamp GUI generates files that are completely different from the original files
- turning Stereo Image *on* but keeping all of its settings off results in *different* changed samples from having it off
Everything *should* be transparent when not being used, no?
Here's my current settings file. "Extra phase shift" would normally be 0.5 for 90 degrees, but I have it set to 0 for testing transparency. Is there a setting I'm missing that is causing things to not be transparent when they should be?
[Common]
Pre amplifier=1
Post amplifier=1
Extra loudness=0
Hard limit output=0
Process for low latency=0
Mode=Advanced
[Noise Gate]
Enabled=0
Difference=0
Noise level=0.800000012
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Maximum value=24576
Attack speed=0.00009
Decay speed=0.100000001
Above Top Limiter=0
[Pre Compressor]
Enabled=0
Difference=0
Delay enabled=0
Maximum volume - Band 1=68640
Maximum volume - Band 2=14230
Attack speed - Band 1=0
Attack speed - Band 2=0.000005001
Decay speed - Band 1=0.001414664
Decay speed - Band 2=0.000249943
[Multiband Compressor]
Enabled=0
Difference=0
Delay enabled=0
Very high quality enabled=0
Maximum volume - Band -1=5380
Maximum volume - Band 0=6260
Maximum volume - Band 1=6750
Maximum volume - Band 2=6940
Maximum volume - Band 3=6850
Maximum volume - Band 4=6310
Maximum volume - Band 5=5670
Maximum volume - Band 6=4990
Maximum volume - Band 7=3720
Maximum volume - Band 8=1560
Attack speeds linked=1
Attack speed - Band -1=0.000049975
Attack speed - Band 0=0.000049975
Attack speed - Band 1=0.000049975
Attack speed - Band 2=0.000049975
Attack speed - Band 3=0.000049975
Attack speed - Band 4=0.000049975
Attack speed - Band 5=0.000049975
Attack speed - Band 6=0.000049975
Attack speed - Band 7=0.000049975
Attack speed - Band 8=0.000049975
Decay speeds linked=1
Decay speed - Band -1=0.000399904
Decay speed - Band 0=0.000399904
Decay speed - Band 1=0.000399904
Decay speed - Band 2=0.000399904
Decay speed - Band 3=0.000399904
Decay speed - Band 4=0.000399904
Decay speed - Band 5=0.000399904
Decay speed - Band 6=0.000399904
Decay speed - Band 7=0.000399904
Decay speed - Band 8=0.000399904
Above Top Limiter=0
Clipping enabled=1
Postprocessing enabled=0
Relative clip position - Band -1=3
Relative clip position - Band 0=3
Relative clip position - Band 1=2.508771658
Relative clip position - Band 2=1.985074759
Relative clip position - Band 3=1.985074759
Relative clip position - Band 4=1.985074759
Relative clip position - Band 5=1.985074759
Relative clip position - Band 6=1.985074759
Relative clip position - Band 7=1.985074759
Relative clip position - Band 8=1.985074759
Final limiter value=1
Final limiter decay speed=0.000700178
Final limiter clipping=2.508771658
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=0
AZIMUTH change speed=0
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=20
[Final Limiter]
Enabled=0
Difference=0
Pre-amp=1
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:
WWW.STEREOTOOL.COM
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing -
http://www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 -
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Device ID=SigmaTel Audio
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Device ID=
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
