PostPosted: Thu Mar 02, 2017 6:03 am
Greetings!
Just trying out this unique and interesting tool when I noticed that there seems to be a brickwall filter at approx 24kHz, even with all processors bypassed. Unfortunately this makes it irrelevant for me when working at rates above 48kHz.
Is this an intended behaviour? Does Stereo Tool only support rates up to 48kHz?
I can supply images if that helps clarify.
Thanks for any feedback!
-J
PostPosted: Fri Mar 03, 2017 2:23 pm
For now, yes. If you're only using things like the Declipper, the "Perfect Declipper" plugin does support higher sample rates. For Stereo Tool, which is mainly aimed at broadcast, that has never really made sense (and it would double or quadruple the CPU load and memory usage if you go to 96 or 192 kHz).
