 Post subject: Installation of 3.x
PostPosted: Mon May 19, 2008 7:23 am
I just recently installed 3.03 and 3.10, seperately of course and currently using 3.10(beta).
Having saved my sts setting for example " studio9.sts " and then attempt to load this setting the name of the setting will not stay in the display box.
I am currently testing two different settings studio9 and studio9(new) neither IF I select eithe rone will remain inthe text box displayed.
Now, I ask mnyself is this a bug or a feature not inplemented as this occurs in 3.03 as well as 3.10(beta).
regards
mapleleaf
 Post subject: Re: Installation of 3.x
PostPosted: Wed May 21, 2008 7:19 pm
The text box (I assume you mean the preset box) currently only displays the presets that I created. It might indeed be a good idea to automatically add others to the list - I will keep it in mind for future versions.
