PostPosted: Fri Dec 30, 2016 1:10 am
My current flow is the following:
FLAC encoder -> Internet -> Stereo Tool decoder (via VLC) -> internal processing -> FM Transmitter output AND Normal output (via VLC, to internet).
If the encoder goes down (resulting in a 404), Stereo Tool crashes / stops responding (or maybe VLC, behind it?). This applies to 8.14 as well. No virtual audio cable is used.
Important parts of the config file:
[FM Transmitter]
Calculate FM signal even if no FM high samplerate output is generated=0
Enable UECP=1
Enabled=1
FM lowpass enabled=1
FM lowpass frequency=16049
FM overdrive volume=1
Mode=UECP
Non-phase linear de-emphasis=0
Output is pre-emphasized=1
Pilot signal volume=9
Polar stereo=0
Pre-emphasis time=50
Pre-emphasize=1
Stereo encoder enabled=1
[Soundcard - Input]
ASIO Override channel 1=-1
ASIO Override channel 2=-1
Balance=1
Buffer size=0
Device ID=Stream (via VLC)
Gain=1
Sample rate=48000
Stream URI=[STREAM_URL_OGG]
Synchronize display with=Normal output
Synchronize to output - Quality=32
Synchronize to output - Relative adjustment=0.020099999
Synchronize to output enabled=0
[Soundcard - Normal output]
Auto-restart=0
Auto-restart if above=2
Auto-restart if below=0
Buffer size=0.692700028
Enabled=1
FM transmitter synchronization enabled=2
Signal selection=Normal
Synchronize via FM sample rate - Extra delay=0
Synchronize via FM sample rate - Maximum const sample rate change=0.001
Synchronize via FM sample rate - Maximum sample rate change=0.01
Synchronize via FM sample rate - Quality=6
Synchronize via FM sample rate - Relative adjustment=0.0051
Synchronize via FM sample rate - Turbo=0.008
VLC Output string=--sout=#transcode{vcodec=none,acodec=mp3,ab=128,channels=2,samplerate=44100}:std{access=shout,mux=raw,dst=source:[PASSWORD]@[IP:PORT/NAME.mp3]} --sout-shout-mp3
Turning off the VLC output stream (with only the FM - sound card output remaing) fixes the crash.
Any suggestions are appreciated. Let me know if you need more info.
Thank you!
PostPosted: Sat Dec 31, 2016 8:38 pm
Unfortunately VLC turns out to be very unstable, and if it goes down it takes Stereo Tool with it. The latest Stereo Tool beta *should* restart when this happens. And log the cause of the crash, if you create a directory c:\temp
