PostPosted: Thu Dec 29, 2016 9:55 pm
I use this VST plug-in in BreakawayOne. When i want to save the settings, it's all ok. But when i'm trying to open the file (.dcl), the plug-in / host crashes. Strange thing is that it is loading my last settings when i close it, and open it again, so it seems.
Maybe i also have to report it to Leif, but my guess is that it's the VST plug-in causing it. I also remember that version 2.00 didn't had this issue so.
PostPosted: Sat Dec 31, 2016 8:40 pm
This must be a bug in my code. Might be an easy one to find and fix, I'll take a look. Probably next year though! :)
PostPosted: Sat Dec 31, 2016 11:31 pm
Yup, found it! Next beta should be ok again.
