PostPosted: Mon May 19, 2008 7:17 am
Since there is an ever increasing number SAMBC users using ST(Stereo Tool), it would be helpful to have during the installation of ST for the installation process to ask the user IF they wish to install ST in Winamp or SAMBC.
Since the current installtion of ST installs into the Winamp --> Plugins directory and then copying the dll into the SAMBC plugin directory.
Thus for example the installation of ST will ask:
Do you wish to install Stereo Tool in
1. Winamp
or
2. SAMBC
Winamp install ST into the Plugins directory whereas in SAMBC it installs into the plugins directory.
Is this a suggestion worth considering?
regards
mapleleaf
PostPosted: Wed May 21, 2008 7:21 pm
Ok, my SAM installation automatically look in the Winamp plugins directory. It's been a few years since I installed it, I guess there must be a settings somewhere in SAM for this...
I'll keep this in mind for future versions... (At the very least I could check before installing if SAM is installed on the pc.)
