PostPosted: Tue Jan 26, 2010 10:17 pm
I dub my precedassor !
Due to little baby I can't enjoy night music. Earphones are not an option neither as I have to hear the baby.
Can I get appropriate StereTools settings for night time listening?
Genres I used to listen to are:
- classical
- jazz
- alternative
- funky
- vintage reggae
Please dear experienced users - if feasible - prepare some set of presets for general audience not only for professional, broadcast-oriented people. I do not stream, I do not FM. I just want to enjoy quality music compression, to listen to the music at low volume, though keeping quiet parts audible and avoid abrupt loudness.
Thank you,
PostPosted: Wed Jan 27, 2010 5:34 am
You can try my latest preset. Goal is to retain source quality while flatting out dynamic range overall. Refer to the attached screenshot to see what this does, and if it will work for you.
Code (save in a new text file with extension .sts):
[Common]
Pre amplifier=4
Post amplifier=0.849999964
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.224999905
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Enabled=0
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=0
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=0
Process for low latency=0
Mode=Advanced
[Noise Gate]
Enabled=1
Difference=0
Noise level=4
Relative noise gate level - Band 3=1.857142687
Relative noise gate level - Band 4=1.857142687
Relative noise gate level - Band 5=3.651162148
Relative noise gate level - Band 6=3.651162148
Relative noise gate level - Band 7=3.651162148
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=2.5
Attack speed=0.000004619
Decay speed=0.008889742
Above Top Limiter=0.189999998
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=32509.998046875
Maximum volume - Band 2=23500
Attack speed - Band 1=0.000001781
Attack speed - Band 2=0.000001781
Decay speed - Band 1=0.000539601
Decay speed - Band 2=0.000539601
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Very high quality enabled=1
Maximum volume - Band -1=8950
Maximum volume - Band 0=8950
Maximum volume - Band 1=8309.999023438
Maximum volume - Band 2=8000
Maximum volume - Band 3=7850
Maximum volume - Band 4=7399.999511719
Maximum volume - Band 5=3850
Maximum volume - Band 6=5950
Maximum volume - Band 7=2159.999755859
Maximum volume - Band 8=3550
Attack speeds linked=1
Attack speed - Band -1=0.000001086
Attack speed - Band 0=0.000001086
Attack speed - Band 1=0.000001086
Attack speed - Band 2=0.000001086
Attack speed - Band 3=0.000001086
Attack speed - Band 4=0.000001086
Attack speed - Band 5=0.000001086
Attack speed - Band 6=0.000001086
Attack speed - Band 7=0.000001086
Attack speed - Band 8=0.000001086
Decay speeds linked=1
Decay speed - Band -1=0.001828427
Decay speed - Band 0=0.001828427
Decay speed - Band 1=0.001828427
Decay speed - Band 2=0.001828427
Decay speed - Band 3=0.001828427
Decay speed - Band 4=0.001828427
Decay speed - Band 5=0.001828427
Decay speed - Band 6=0.001828427
Decay speed - Band 7=0.001828427
Decay speed - Band 8=0.001828427
Above Top Limiter=0.75
Clipping enabled=0
Postprocessing enabled=1
Relative clip position - Band -1=-1
Relative clip position - Band 0=-1
Relative clip position - Band 1=-1
Relative clip position - Band 2=-1
Relative clip position - Band 3=-1
Relative clip position - Band 4=-1
Relative clip position - Band 5=-1
Relative clip position - Band 6=-1
Relative clip position - Band 7=-1
Relative clip position - Band 8=-1
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=20
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Stereo Boost Excessive Reverb Protection Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=14.999999046
AZIMUTH change speed=0.25
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=2
Stereo Boost maximum amplification=3.5
Stereo Boost multiplier=0.550000012
Stereo Boost - Never reduce below original level=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=17500
Highpass filter=19.999998093
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.25
Pre-limiter enabled=1
Pre-limiter relative volume=1.25
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Device ID=
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
File comment: Before (Top) and After (Bottom)
 Post subject: Re: PROBLEM !!!
PostPosted: Wed Jan 27, 2010 2:01 pm
Hmm,
It does not seem to work (all panels gone gray while applying preset file prepared the way you advised).
Would you be so kind, please, to attach a working STS file rather than listing?
Thanks ahead,
Ziggi
PostPosted: Thu Jan 28, 2010 4:27 am
Try this one, it is even flatter for your needs.
Unzip first (extension .sts is not allowed).
Set your volume control to the peak of the audio.
CLA-H.zip [2 KiB]
Downloaded 987 times
 Post subject: THANK YOU !!!
PostPosted: Fri Jan 29, 2010 12:21 am
Now it works like a charm !!!
I appreciate your effort - thank you very much for your help!
Rgs,
Ziggi
PostPosted: Fri Jan 29, 2010 4:54 am
Is the level flattened enough for you?
I'm working on evolving that, without losing "punch" so to speak.
Try this:
CLA-I.zip [2 KiB]
Downloaded 884 times
PostPosted: Fri Jan 29, 2010 12:40 pm
There's also this one, which isn't as aggressive at transient attenuation.
CLAJ.zip [2 KiB]
Downloaded 869 times
PostPosted: Thu Feb 04, 2010 4:11 am
Nothing is ever perfect. There are always tradeoffs for processing.
Here is one which pumps much less:
CLAL.zip [2 KiB]
Downloaded 935 times
