Simple or Basic, referred to control the speed (which influences Attack, Hold and Release), Energy or Density (Thresholds, Knee, Peak / RMS Ratio), Mix (Band Mix)
You mean all these settings per band, or a single "Density" setting? There's already - even in Simple mode - the Drive and Output level, which I think should be enough for that (because: How would a Density slider affect Knee for example. And Threshold is basically linked to Drive, so that's already ok. Although using a very different drive level might cause big issues if the ratios for bands are different. Grrrr...
What I say is to simplify all in one setting, you just have to find the proportions of each to be consistent. As a user, in Basic mode, just move a slider but internally would adjust several parameters at once (in a predetermined relationship).
I think a little is what you are proposing to "Density" control.
