New Linux GUI version, now with Jack support. No parameters needed!
http://www.stereotool.com/download/ster ... ETA724-019
ONLY FOR TESTING, this version is not at all suitable to do actual processing, I just want to know if it works properly (sound comes out, no hiccups).
Notes:
- jackd must be running (use qjackctl to see what's happening - you should see it connect there).
- Only normal input and normal output work, for now.
- Because I'm not sure if I'm doing everything correctly yet I'm adding a soft beep tone to the input.
- FM presets don't work and output silence - I don't know why yet. Use default settings (no processing) or generic or web presets.
- Program closes after 60 seconds!
- Latency is hardcoded to be 250 ms.
Testing this in a VMware environment is giving pretty bad results (some weird things happen with the Windows sound drivers in combination with VMware as soon as I start jackd; after killing this Windows driver everything works fine but I can't hear anything), I need to do a native install on another pc for proper testing.
