Post new topic  Reply to topic  [ 1012 posts ]  Go to page Previous 175 76 77 78 79102 Next
PostPosted: Tue Mar 12, 2013 11:28 am
Also 4 % less CPU on our Breakaway-Server-PC. Before 30 %, after 26 %...
PostPosted: Tue Mar 12, 2013 1:01 pm
Something is wrong with the dsp version, at least with my settings, which worked fine with beta52
No output, flickering in the MB levels display, Advanced clipper full colored display
VST works fine in Audition, same settings
AMD A8-3870 , win7 64
WunjoV3.sts [44.31 KiB]
Downloaded 317 times
PostPosted: Tue Mar 12, 2013 1:29 pm
Will stereo separation be fixed in compressor(s)?
PostPosted: Tue Mar 12, 2013 2:19 pm
For me is CPU : 25 31% .. average 28 % . GOOD :)
PostPosted: Tue Mar 12, 2013 2:30 pm
I really need to make a list of things that need to be fixed before I can release this version. Please let me know if I miss anything:
- Show 1 or 2 AGC bands in bottom meters is 1 or 2 used. -> Annoying side effects, not going to do this now.
- I think I should probably remove the 'Use side chain' button, to make it work the same as all other side chains.
- I think I need to put the top line of Multiband sliders (which are very small) in a separate page.
- Add hold multiplier; in Simple mode replace all multipliers by one.
- And change the scale of the Drive slider indeed. -> Probably affects ALL sliders with values in dB's!
- Compressor: Fix stereo separation in Peak mode
- Multiband Compressor: Display coupled bands - Done, but without coupling is no longer visible!
- Multiband Compressor: Median displays (new MB only)
- Remove "blob" from Knee
- Equalizer: More resolution for lower bands - Twice as steep allowed now. #define peq_steep.
- Sound cards: Make 'Synchronize to output' work with Normal output To be tested; might crash/hang
- Multiband compressor: Differentiate between Basic/Advanced/Extreme... modes
- Singleband Compressor: Differentiate between Basic/Advanced/Extreme... modes
- Compressor side chain causes volume jumps (block overlap issue).
- Some default logical Band crossover settings for MB (every number of bands)
- Check Wunjo's issue with BETA053 (very likely either a memory alignment or a too-aggressive-optimization problem). Appears to be in the "Knee" code. (Error in LUT?)
- Crash reported by Christian Steifen: If you change to a different category and quickly change something it crashes (VST version).
- Hosts issue
- Update presets
- Change version number
- Release
PostPosted: Tue Mar 12, 2013 2:35 pm
[quote="Wunjo"]Something is wrong with the dsp version, at least with my settings, which worked fine with beta52
Could you send me your .ini file in a PM? With this STS file I cannot reproduce the issue.... :(
It sounds like the MB is outputting invalid values (Not A Number or NaN, which can result in overflows in the next filters).
PostPosted: Tue Mar 12, 2013 3:21 pm
Take this opportunity to make a comment about the activation of Side Chain Compressor both the AGC and the SingleBand.
I think it confuses the fact activation, first "Use Side Chain" and the other "PEQ Sidechain". I think that when you activate the "Use Side Chain", you should activate the "PEQ Sidechain" or directly take this last check, because without the EQ sidechain is meaningless.
Another control display has a problem, is the "Drive" the MB, where the maximum is 42 dB, and put half the control is 36 dB. Is there a problem of scaling or calculation of dB. With the "Output level" goes something like this.
@Hans,
What do you think of this?
by GAP
"Less is More" (Bob Katz)
PostPosted: Tue Mar 12, 2013 3:25 pm
What about EQs ?
- More resolution for lower bands
- Peq Sliders (?)
PostPosted: Tue Mar 12, 2013 3:28 pm
Ah, good one. I think I need to put the top line of sliders (which are very small) in a separate page. But also change the scale of this Drive slider indeed.
PostPosted: Tue Mar 12, 2013 3:31 pm
What about EQs ?
- Peq Sliders (?)
Added most of these to the list; Peq sliders probably later but I'm not going to do that now. (Not going to hold off the release of a new version for that).
