Post new topic  Reply to topic  [ 387 posts ]  Go to page Previous 15 6 7 8 939 Next
PostPosted: Tue Feb 28, 2012 6:01 pm
Now it's there.
PostPosted: Tue Feb 28, 2012 6:21 pm
Now it's there.
Thank you so much :)
Would be great if modern C++ compilers/IDEs have something like incremental build as we have in Eclipse for JEE projects. Think that should save quite a bit of compilation time. Not sure though.
visit website
PostPosted: Tue Feb 28, 2012 9:27 pm
Here is this song . It`s difficult song to handle i think but take the settings and play the song . I think You will find that after 3:30 minute of the song we don`t need the limit between the bands in AGC ( band 1 not to go above band 2 and band 3 not to go above band 2 ) . See where is the middle frequencies and where is the bass ? Level of middle frequencies suppress the bass . If i`m wrong then correct me .
The song is old and good .So happy testing.
http://www28.zippyshare.com/v/65124666/file.html
If still not agree with me then download this song and listen after 7:00 minute. It`s another version of the first song.
http://www28.zippyshare.com/v/66197768/file.html
Doggy.rar [3.64 KiB]
Downloaded 351 times
PostPosted: Tue Feb 28, 2012 9:31 pm
This is about Loudness indeed.
Is there any chance that you could refer to Loudness as Loudness, and FM-only clipper as "clipper"?
I know this may seem like a moody nitpick, and I have to confess I am in a grumpy mood (still not even a phone call for a job), but if you use the term "clipper" to reference something that is called "Loudness" in the application itself, that can and does frustrate end-users who may not have seen where you have referenced Loudness as a clipper in the past.
If you go look at the Firefox Builds forum, some time ago there was someone grumping about how they were having problems with Firefox Aurora and how that they didn't like all the hassle involved in being a "beta tester". I am on there as "Amelius", and I pointed out to them that Aurora = alpha, and Beta = beta.
My opinion there was that they had too high expectations for alpha, and that they should switch to beta. My opinion here is that you may be expecting people to follow conversations to the degree of what would equate to an alpha, but calling these things beta releases. The software itself is of beta quality, it's just the expectation of people to innately know what you're talking about may be set a bit too high.
PostPosted: Tue Feb 28, 2012 10:59 pm
Uauuuuuuuuuu something's strange i pass from 49% CPU load to 65% with this new vers. !!!!!!!!!! something is not right i think.... to much :o
VST
Reverse to 6.21 VST !!!
http://www.kanal80.net
Best 80's & 90's Music
PostPosted: Tue Feb 28, 2012 11:05 pm
That is only when there is no Audio input to Stereo Tool. It'll be fixed.
PostPosted: Tue Feb 28, 2012 11:12 pm
not right... sorry runing it with stream and CPU load stills fix at 65% with 6.21 same config 49%.... VST version
PostPosted: Tue Feb 28, 2012 11:19 pm
It's still in beta, so you can expect higher cpu loads / more memory usage.
PostPosted: Tue Feb 28, 2012 11:26 pm
As always great finding from you, i've notice that :shock: just simply wanna notice that. sorry for my comment
PostPosted: Tue Feb 28, 2012 11:39 pm
I'm sorry i responded to it, i'll try to not do that again.
