Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 97 posts ]  Go to page Previous 13 4 5 6 710 Next
 Post subject: Re: Stereo Tool 7.82
PostPosted: Wed Nov 18, 2015 1:11 pm
May be it`s high but as i said i don`t want AGC to pump up and down like some "crazy psycho" . For me it must be auto regulator of the level and must be relatively stable.
There are many other functions that can be maked as freak "fast speed" pumps that make sound like "ultra compressed" . I don`t like that much compression. My limit for the compression is arround -12 db , according to ITU BS1770 meter
PostPosted: Wed Nov 18, 2015 1:46 pm
Gate level is multiplied by Pre Amp if "Gating based on volume before Pre Amp" is disabled. That's it. It's there for convenience (you can drive Pre Amp harder without changing gating behavior, but you will get more compression or AGC action).
PostPosted: Wed Nov 18, 2015 2:40 pm
I`m talking for exactly this : I`m using it always ON and it`s a useful option for me. I don`t think it must be removed !
PostPosted: Wed Nov 18, 2015 6:56 pm
Seems switching bypass on and off does not make problems anymore when sync is ON or Auto. Still i have some drops on win7 a buffer size 50ms sometimes with buffer bar full. Also at those small latency ~50ms seems input sync have hard time to sync.
At 100ms buffer sync works.
PostPosted: Wed Nov 18, 2015 6:59 pm
I still think both are exactly same.
PostPosted: Thu Nov 19, 2015 12:16 am
Little bug: True Bass has abbreviation in "graphs" display part "WB" instead of "TB" - remain from Warm Bass probably.
PostPosted: Thu Nov 19, 2015 1:04 am
Based on chat with Bojcha and his and my tests:
- Sync works in 7.73 from 80 ms, in 7.82 from 100 ms, most likely cause is that I aligned my buffer size checks with the sound card code (which is actually better because it's more predictable).
- Low latency values (80 ms) work fine in 7.82 when using VAC or Realtek, but not with Juli@! So something must be affecting the Juli@ driver - somehow. :(
Ahhhh.. More chat. Sync was enabled for the Juli@ (AUTO mode, and input was coming from VAC).
So:
Ok anyway.... seems all is kinda ok if I do something with auto sync and buffer sizes
So either disable AUTO SYNC for small buffer (actually that makes sense, if it causes issues people will probably increase the buffer size), or don't allow small buffer sizes when Sync is used.
Latter seems to be a better idea; maybe show a warning that the small buffer size is ignored due to sync.
PostPosted: Thu Nov 19, 2015 2:13 am
Since I had so much trouble to get stereo tool 7.7x initially working with windows 10 I just wanted to say, stereo tool 7.82 runs really well at the moment, happy to see the whole JACK ASIO interface work so stable after this last windows 10 update:
Thats not 11 seconds or minutes, thats 11 hours of error-free audio :D JACK just feeds into ASIO4ALL by the way, gives me a nice and acceptable total delay to which you can still watch videos without wondering whats going on. I have all sync options disabled as well as "reduce buffer clicking" disabled because I had more issues with that than without.
PostPosted: Fri Nov 20, 2015 3:25 pm
I tried everything.I still have hiccups.Maybe its a problem in windows 10?
PostPosted: Fri Nov 20, 2015 3:28 pm
Not if it doesn't happen with version 7.73...
Could you give me TeamViewer access to your system? So I can have a look?
