Post new topic  Reply to topic  [ 445 posts ]  Go to page Previous 13 4 5 6 745 Next
 Post subject: Re: Preview...
PostPosted: Mon May 04, 2009 5:10 pm
Hans,
is it correct that the load preset function is not yet working?
/Martijn
If that's the case than I've done something wrong - I though that it still worked. (It was already present on this screen before I changed anything).
I'll look into it.
Note: I am going to replace that part of the interface also, but it will probably take more time...
PostPosted: Mon May 04, 2009 8:26 pm
Gotta another little problem....
When you have several windows open, like stereo image and loudness, you untick one in one window and untick in the other window, the one you unticked previously, ticks itself again.
PostPosted: Mon May 04, 2009 9:02 pm
I can't seem to reproduce this... Are you using the latest version? And can you tell me exactly what you are doing? I've tried enabling and disabling several things in both windows (Stereo and Final Limiter), and it seems to work as expected...
PostPosted: Mon May 04, 2009 10:08 pm
i don't understand too ..
but i found that right click on Final-Limiter/Loudnes not working on latest beta. (standalone)
PostPosted: Mon May 04, 2009 10:17 pm
sorry, must had been a previous version. working okay now. :oops:
PostPosted: Tue May 05, 2009 2:49 am
No it's not :oops: ... I think what you saw is the following: If you have selected a preset, the preset dropdown box remains selected. If you then put the focus on the main window again, Windows reports this as a click on the preset dropdown box to Stereo Tool... which responds by re-loading the already active preset which you had just changed a bit...
I'm not going to solve this right now, because I'm going to change the way presets work anyway - I want to start using different categories (similar to the current categories), but such that only one category is displayed simultaneously. That should make things less crowded. And it will allow me to add user-defined presets.
PostPosted: Tue May 05, 2009 4:33 am
Update:
- Made CPU buttons a bit bigger
- Added Bypass button (Martijn!)
- Fixed a bug which caused strange effects (blocks of bad pixels) in the displays.
PostPosted: Tue May 05, 2009 1:29 pm
YES! thank you Hans.. The load presets is also working again...
Martijn
PostPosted: Thu May 07, 2009 1:58 am
By the way, I just loaded the "FM Loud" preset and moved the "Pre Amp" slider to 1 - the sound that I'm getting is much closer to the original but still very loud.
I think it sounds even better when I use "FM Transmitter", set Pre Amp to 1 and Loudness to 4.
I think I'll add one or both of these as a preset.
PostPosted: Thu May 07, 2009 6:45 pm
Congratulation for the new look and the improvement of the Stereo Tool, I have tried to select FM Transmitter Europe Stereo and set the Pre Amp to 1 and Loudness to 4, I am getting a loud and much better sound, but i could see no movements in the multiband compressor colored indications. I just wondered if this is normal, and is the multiband compressor functioning now with the reduction of the pre Amp signal?
Kind reagrds,
Abdul
