Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 131 32 33 34 3548 Next
PostPosted: Tue May 05, 2015 3:38 pm
There are bugs in the latest beta pertaining to input and output card selection. No crashes so far, but it doesn't respect the choices you make until after ST is restarted. At first I thought there was a preset loading bug where those settings were not loaded (there could still be, but I don't believe so).
PostPosted: Tue May 05, 2015 8:42 pm
I'm making the rounds back to Hansland at the moment. I just installed the latest beta.
I've been waiting a long time to be able to put real effort into Stereo Tool. Partly for it to progress technically to the point where I felt it was worth a serious effort. That happened around v7.4x-ish. And partly because some of you know that I'm becoming part of the Omnia family over the last 10 years. Not being able to help one of our progressively serious competitors is not a problem anymore because Hans has finally joined us!! :)
So... I'll let the deep-topic readers know here first... I *have* been working on a preset for Stereo Tool for the last two years. Much more seriously this year. It will be in the next full version of Stereo Tool, possibly with multiple versions depending on the amount of dynamics you want to have. 14dB is my personal favorite. Bojan tells me that it is very different from any other preset he has heard, and now seen, for Stereo Tool. :) Hans tells me that the action is very similar to what he wanted to do with the new "Multiband 2" (before he even started on the multiband version of that compressor), and I'll be checking out the new Multiband 2 over the next few days.
TLDR; I've heard some of you were recently asking if there will be a preset/s by me... Yep. 8-)
Hooray!! :D
PostPosted: Tue May 05, 2015 10:35 pm
I am so ready for release of 7.61. Good to hear from you Jessie.
PostPosted: Wed May 06, 2015 2:40 am
alone vercion more good vts with deckadance ı have maya 44 sound card deckadance open line in super sound quality
PostPosted: Wed May 06, 2015 3:48 am
BETA 761-034
Windows stand alone: -ttp://www.stereotool.com/download/stereo_tool ... 61-034.exe BROKEN
Winamp DSP: -ttp://www.stereotool.com/download/dsp_stereo_ ... 61-034.exe BROKEN
VST 32bit: ----://www.stereotool.com/download/vst_stereo_ ... 61-034.dll (NOT AVAILABLE)
This version doesn't work, it worked in debug mode (which I tested) but the compiler optimized some things too aggressively.
Note: Something is wrong with the VST build (the compiler exits with an out-of-memory error, and my build system has 16 GB of memory - I need to check what changed).
Note #2: I have enabled the NAN checks again (which means that you might see error messages - if so please tell me - and the CPU load is a bit higher).
- Fixed Exception that several people reported when changing Gate Freeze settings (was caused by a GUI issue)
- Improved gate GUI display
- Made after-AGC compressor switchable as well
- Fixed delay of Delossifier in display
- Improve limiter GUI display
- Don't allow Threshold values below 0.5 dB (singleband, others are already ok)
- Optimize gating (turn off if not needed)
- Made 'limit before compress' again, switchable
- Add Gate for new compressor release (also GUI)
- Band Link etc. does not work in 3-band mode, and it should for AGC-type behavior.
- Simplify interface (remove Oil Speed Adjustment sliders etc, move some things to Extreme Tweaker mode)
- Adjust limiter level for Band Mix
- Fix 'Load default values' question for MB #bands change
- Make Shape value small for high speeds - TO BE DONE: Test if the border value is chosen correctly (shape effect is deminished below 40 ms, reduced to '1' for 0 ms; not sure if 1 is low enough?)
- Fixed some more GUI crashes. They should all be fixed now...
- Check if audio is still the same as in older versions (!)
- Set MB2 default settings ok for NAB demoing (very fast)
- Fixed some (but not yet all!) GUI crashes
- Improved CPU performance a bit, on multiple places (clipper, GUI).
- GUI crashes from previous beta's are probably fixed (?)
- Changed some GUI things (for big displays)
- Small performance optimizations
- Limiter behavior visible in meters
- Fixed MB ITU mode.
- Fixed Median display in Analog mode
- Made final SB compressors switchable, parameters are also shared between analog and digital now.
- Added limiters to singleband and multiband Analog compressors. Warning: Meters are not yet visible in the GUI! Which makes it kinda difficult to setup (you can use Monitor to see the output of a single band and then adjust the limiter setting).
- I fixed something in the GUI but I had a situation where I couldn't start it earlier tonight so it's probably not completely fixed yet.
- Some settings from the 2nd MB overruled the 1st, causing all kinds of effects. That has been fixed now, and I verified that the audio of Digital mode in the 1st MB is (nearly) identical to that of BETA761-016 (nearly because in 016 the frequencies still were 10% off). New quickly put together preset (NICE2) attached.
Fix MB frequency band shift (10%, since 7.51 or 7.60) - Appears to be gone but I don't remember fixing it (!)
Fix RDS time issue! viewtopic.php?f=6&t=5941&p=28209#p28209
Added 2nd Multiband compressor! Example preset is attached below. To me, turning it off makes the sound boring/empty. I think this is exactly what some people were missing in Stereo Tool. And with 2 steps the audio is also more consistent than before. RMS/ITU based preset would probably be even better... To increase or decrease the effect, adjust the Density slider of the 2nd Multiband compressor!
- Optimized CPU load. CPU load now strongly depends on the settings, for the settings that I posted earlier it's now less than half that of Digital mode! On my system it went down (single core mode, CPU load on that core) from 12.3% to 2.5%! (Again, depending on settings). Digital uses 9.1%.
- Merged more parameters (Peak vs RMS setting) with old ("digital") compressor.
- Slower Release speed in Analog compared to Digital
- Removed Shape Enable settings.
- Fixed Knee in Analog mode
- Fixed Aggressiveness slider behavior for Analog (!), made it behave the same as Digital mode (acts only on release speeds).
- Merged more parameters (Attack Time, Release Time) with old ("digital") compressor. Adjusted numbers in Digital compressor to match the (correctly calculated) behavior in Analog mode.
- Merged parameters (threshold, knee, ratio, feedback, channel separation, band mix) with old ("digital") compressor, I noticed that I was switching back and forth all the time to copy settings, so this seems easier. Threshold is now also displayed in dB's.
Made Multiband version of the new compressor! Choose 'Analog' mode to switch to the new one. See attached preset for an example!
- Made new Traditional Peak mode which behaves more like normal Peak.
- Added Lookahead, removes huge spikes at start of attack for fast attack times and reduces IMD.
- Fixed Ratio behavior
- Fixed 'Density Drive' slider in Analog mode
- Fixed no audio with certain combinations of filters
- Fixed a filtering issue in the Digital compressor (!) when using Density Drive > 1.00
- Added lowpass filter to control signal to smooth out bad effects and remove distortion
- Added ITU-1770 mode to reduce pumping and improve level control
- Added Channel separation
- Rewrote all code
- Fixed Ratio
- Channels are not processed separately (wasn't the case before, and that was a bug)
- Fixed attenuation display
- Attack and Release times must be set to half the numbers of the previous beta's. Oil change speed must be doubled.
- Restored old Shape behavior from version 009
- Replaced 'Nonlinear Release' by 'Exponential Release', which works better and only needs 1 parameter. Use this to go up FASTER if you're down DEEPER.
- Added Ratio
- Added Feedback mode
- Fixed out-of-control behavior for certain extreme settings
- Fixed some more weird behavior things if the difference between Attack and Release is REALLY huge (behavior was bumpy and caused clicking sounds).
- Known issue: both Shape On settings must be enabled. I will probably remove them in the next build anyway so I'm not going to fix it.
Fixed a lot of bugs, will type the details here later. Oil Temperature is now in % and didn't work properly before. PLEASE LOAD THE DEFAULT SETTINGS for the new compressor or it will sound horrible.
Changed Attack Time, Release Time, Attack Speed Threshold, Release Speed Threshold to understandable values. Made 1.0 the 'standard' behavior for Shape.
- Added smoothing to oil temperature behavior for both attack and release.
Added Oil temperature behavior which was missing from my automatic (hydraulic) door model. Will explain below...
- Added another Peak mode slider in "New Singleband". The old one (from yesterday) works mainly on release, but in some cases the volume didn't go down fast enough on a loud sound. The new one works mainly on attack (higher value makes attack continue AFTER a peak.
- Changed Peak mode behavior in "New Singleband".
- New Singleband: Split Speed into Attack and Release Speed
- New Singleband: Made Attack and Release Speed Threshold relative to Speed - so you don't need to adjust it to change the shape.
TO DO COMPRESSOR:
- Add Drive parameter for each MB band
- Freeze only for all bands combined. Still not sure if this is really a good idea...
- OPTIMIZE LIMITER
- Maybe add downward expander
TO DO:
- Display warning when composite clipper used but not registered.
- EQ with 'standard' sliders.
- Add RDS control via VST typedef VstIntPtr (VSTCALLBACK *AEffectDispatcherProc) (AEffect* effect, VstInt32 opcode, VstInt32 index, VstIntPtr value, void* ptr, float opt); for Bernd N
- Improve Dequantizer by combining data from different block sizes
- Add HD delay (upto 10 seconds? Check Matt Aaron's drawing). Also finally make resampler for normal output to fix 2 output on different sound cards problem. Move Resample setting from input to output. Let's ignore using 2 inputs for now...
PostPosted: Wed May 06, 2015 4:12 am
Stand alone has issues too. It won't run on my 64bit Windows 8.1 laptop. Dropped back to 33B and all good.
PostPosted: Wed May 06, 2015 4:15 am
33 standalone runs fine for me on 64-bit Win 8.1.
PostPosted: Wed May 06, 2015 4:33 am
V.34 DSP version.
Winamp client version:
winamp caused an Access Violation (0xc0000005)
in module dsp_stereo_tool.dll at 0023:5f61eb49.
Exception handler called in Winamp
Home: SummerXl - TuneIn: Summer-Xl SummerXl stream 192 kbps: SummerXl SummerXl
PostPosted: Wed May 06, 2015 5:02 am
Yeah. Me too. It's 34 that doesn't work.
PostPosted: Wed May 06, 2015 9:12 am
I hear something strange in mb filters analog vs gigital, I have ratio 1:1 in both and levels flat but sound is different much.
Urban Junglist
