Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: 7wonders
PostPosted: Wed Dec 28, 2016 3:20 am
Really liking how lo-fi, instrumental hip-hop sounds with this!
PostPosted: Thu Dec 28, 2017 5:12 am
Good morning!
Love the sound of this preset! For offline processing and more dynamic headroom, I made a few changes for personal use. When the original and the result of this setting is volume-matched, there is a major difference. The original just sounds flat, and the stereo image is collapsed.
7wonders_v027_dynamic_offline_use.sts
Below are the list of changes made:
1. Changed MP3 to zero samples since not processing MP3, but may add some benefit
2. Maximum CPU usage on Restoration
3. Enabled Dequantizer and maxed all quality settings
4. Change pre-amplifier to -13.56dB (6dB+7.59dB) - this adds 6dB of additional headroom for dynamic range
5. Changed high-pass frequency from 25Hz to 15Hz, and Low-pass from 18,000Hz to 22,050Hz
6. Changed Advanced Clipper CPU strictness to 20 (maxed) and Medium Stop to 20 (maxed)
Just on a test of Britney Spears "Stronger" (ok, don't judge me :lol: ) Looking at the amplitude statistics the difference is pretty impressive...
Dear friend...help me..what software use for generate this images report? Thanks
Apologies, it’s been awhile and I gotta get up to speed on all the changes! The software I use to generate the data is Adobe Audition. They were also screenshot on a 4K moniter.
