Post new topic  Reply to topic  [ 749 posts ]  Go to page Previous 128 29 30 31 3275 Next
PostPosted: Fri Jan 15, 2010 6:48 am
now it's almost perfect! blckovrlp=0 Highpass=off. Now Bass is same quality as blckoverlap=100 + highpaas=on :) That is nice.
edit:
4096 - BASS is Awesome!! much better and cleaner and same level as 4.22 (maybe even higher) ! Highs are at same level as 4.22 and bit cleaner.. all with blckoverlap=0.
Highpass missing, i hope it will be good too.
Ok - this is weird. Because I'm measuring a MUCH lower bass level (0.5 dB softer). Will check again tonight!
PostPosted: Fri Jan 15, 2010 9:18 am
i just measure again...
beta3a blckoverlap=0, preset web-bassboost, 50Hz bass is exactly same level as v4.22, but much cleaner.
PostPosted: Fri Jan 15, 2010 9:56 am
Yes, but that's for a single tone. If you play music instead, the bass level is lower. (Note: If it's still clean, I could boost the bass a bit afterwards - the peak level of the waveform that comes out is also a bit lower. But I expect that the bass level goes up and down continuously.
PostPosted: Sat Jan 16, 2010 3:02 pm
Hi Hans..
I notice one thing in latest beta3a (maybe with erlier happens but i did;t try) ...
I put it on our transmitter (turned off stereoboost and highpass) blckoverlap=0) and if i put "left slope width" from 100 to 90% i get much higher FM output.
btw .. again.. cpu usage is much better on blckoverlap=0 .. and quality is far better. Maybe is needed some small tweaks but for now is very good.
PostPosted: Sat Jan 16, 2010 8:11 pm
Hi Hans..
First small tweak is coming up (building it right now), it turns out that the volume calculation (used for "clean/punch") was incorrect. That caused part of the lower bass level.
The bass protection filters also lower the bass level a bit, but that should (I need to check it!) only be if it was too loud in the first place.
The bass when not using "Block Overlap = 0" should be a bit better now.
If you touch the "slope width" or "overlap size" sliders with block overlap 0, very strange things may happen - the output may be higher but it will also contain HUGE peaks. Please leave them at their defaults!
(Note: I will eventually implement the "slope width" sliders as a means to further reduce the CPU load - but I'll do that when the rest is finished).
Edit: Build is still running and I have to go somewhere now. So the update will be posted later tonight. But I have some good news too: I think I just found a solution to convert the Stereo Boost filter to Overlap=0 mode...
PostPosted: Sat Jan 16, 2010 11:00 pm
Uploaded - BETA3A again.
PostPosted: Sun Jan 17, 2010 3:33 am
Low-Bass on 512 mode is perfect (and much more level) with blockoverlap=0 ans SlopeOverlap 1-3% :o :D
In the same time mid-lows are missing, but sound is still very clean. No Bass ringing.
For BlockOverlap >0 ... i must ask why is that mode important now.. when with mode blockoverlap=0 is much better results ?
PostPosted: Sun Jan 17, 2010 5:13 am
Small update: Highpass filter is more or less functioning now in "Overlap 0" mode. However:
1. Make sure that you DON'T use the highpass filter with Overlap > 0 before switching to Overlap 0 for the first time, or you'll get horrible clicking sounds. I don't know yet what's causing it, if you move to Overlap 0 before turning Highpass on there's no problem.
2. It's not as good as in Overlap > 0 mode (there are some remaining sounds at the end of each processing block, that's every 2048 samples in 4096 latency mode).
PostPosted: Sun Jan 17, 2010 5:15 am
Not everything is working yet in "Overlap = 0" mode.
I'm surprised about the SlopeOverlap - that shouldn't be the case :shock:
PostPosted: Sun Jan 17, 2010 5:29 pm
It's good with slope overlap=0 .. just a bit cleaner lows with slope 1-3% .. not so important.
High Pass works now witd block overlap=0, it's little better in block overlap >0.
