Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 126 27 28 29 3048 Next
PostPosted: Wed Apr 22, 2015 4:29 pm
I tested stand alone only.
Yes, I was testing the latest standalone also.
PostPosted: Thu Apr 23, 2015 2:26 am
BETA 761-027
Windows stand alone: http://www.stereotool.com/download/ster ... 61-027.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 61-027.exe
VST 32bit: http://www.stereotool.com/download/vst_ ... 61-027.dll
- Fixed some (but not yet all!) GUI crashes
- Improved CPU performance a bit, on multiple places (clipper, GUI).
- GUI crashes from previous beta's are probably fixed (?)
- Changed some GUI things (for big displays)
- Small performance optimizations
- Limiter behavior visible in meters
- Fixed MB ITU mode.
- Fixed Median display in Analog mode
- Made final SB compressors switchable, parameters are also shared between analog and digital now.
- Added limiters to singleband and multiband Analog compressors. Warning: Meters are not yet visible in the GUI! Which makes it kinda difficult to setup (you can use Monitor to see the output of a single band and then adjust the limiter setting).
- I fixed something in the GUI but I had a situation where I couldn't start it earlier tonight so it's probably not completely fixed yet.
- Some settings from the 2nd MB overruled the 1st, causing all kinds of effects. That has been fixed now, and I verified that the audio of Digital mode in the 1st MB is (nearly) identical to that of BETA761-016 (nearly because in 016 the frequencies still were 10% off). New quickly put together preset (NICE2) attached.
Fix MB frequency band shift (10%, since 7.51 or 7.60) - Appears to be gone but I don't remember fixing it (!)
Fix RDS time issue! viewtopic.php?f=6&t=5941&p=28209#p28209
Added 2nd Multiband compressor! Example preset is attached below. To me, turning it off makes the sound boring/empty. I think this is exactly what some people were missing in Stereo Tool. And with 2 steps the audio is also more consistent than before. RMS/ITU based preset would probably be even better... To increase or decrease the effect, adjust the Density slider of the 2nd Multiband compressor!
- Optimized CPU load. CPU load now strongly depends on the settings, for the settings that I posted earlier it's now less than half that of Digital mode! On my system it went down (single core mode, CPU load on that core) from 12.3% to 2.5%! (Again, depending on settings). Digital uses 9.1%.
- Merged more parameters (Peak vs RMS setting) with old ("digital") compressor.
- Slower Release speed in Analog compared to Digital
- Removed Shape Enable settings.
- Fixed Knee in Analog mode
- Fixed Aggressiveness slider behavior for Analog (!), made it behave the same as Digital mode (acts only on release speeds).
- Merged more parameters (Attack Time, Release Time) with old ("digital") compressor. Adjusted numbers in Digital compressor to match the (correctly calculated) behavior in Analog mode.
- Merged parameters (threshold, knee, ratio, feedback, channel separation, band mix) with old ("digital") compressor, I noticed that I was switching back and forth all the time to copy settings, so this seems easier. Threshold is now also displayed in dB's.
Made Multiband version of the new compressor! Choose 'Analog' mode to switch to the new one. See attached preset for an example!
- Made new Traditional Peak mode which behaves more like normal Peak.
- Added Lookahead, removes huge spikes at start of attack for fast attack times and reduces IMD.
- Fixed Ratio behavior
- Fixed 'Density Drive' slider in Analog mode
- Fixed no audio with certain combinations of filters
- Fixed a filtering issue in the Digital compressor (!) when using Density Drive > 1.00
- Added lowpass filter to control signal to smooth out bad effects and remove distortion
- Added ITU-1770 mode to reduce pumping and improve level control
- Added Channel separation
- Rewrote all code
- Fixed Ratio
- Channels are not processed separately (wasn't the case before, and that was a bug)
- Fixed attenuation display
- Attack and Release times must be set to half the numbers of the previous beta's. Oil change speed must be doubled.
- Restored old Shape behavior from version 009
- Replaced 'Nonlinear Release' by 'Exponential Release', which works better and only needs 1 parameter. Use this to go up FASTER if you're down DEEPER.
- Added Ratio
- Added Feedback mode
- Fixed out-of-control behavior for certain extreme settings
- Fixed some more weird behavior things if the difference between Attack and Release is REALLY huge (behavior was bumpy and caused clicking sounds).
- Known issue: both Shape On settings must be enabled. I will probably remove them in the next build anyway so I'm not going to fix it.
Fixed a lot of bugs, will type the details here later. Oil Temperature is now in % and didn't work properly before. PLEASE LOAD THE DEFAULT SETTINGS for the new compressor or it will sound horrible.
Changed Attack Time, Release Time, Attack Speed Threshold, Release Speed Threshold to understandable values. Made 1.0 the 'standard' behavior for Shape.
- Added smoothing to oil temperature behavior for both attack and release.
Added Oil temperature behavior which was missing from my automatic (hydraulic) door model. Will explain below...
- Added another Peak mode slider in "New Singleband". The old one (from yesterday) works mainly on release, but in some cases the volume didn't go down fast enough on a loud sound. The new one works mainly on attack (higher value makes attack continue AFTER a peak.
- Changed Peak mode behavior in "New Singleband".
- New Singleband: Split Speed into Attack and Release Speed
- New Singleband: Made Attack and Release Speed Threshold relative to Speed - so you don't need to adjust it to change the shape.
TO DO COMPRESSOR:
- Check if audio is still the same as in older versions (!)
- Set MB2 default settings ok for NAB demoing (very fast)
- Simplify interface (remove Oil Speed Adjustment sliders etc, move some things to Extreme Tweaker mode)
- Make after-AGC SB compressor switchable as well
- Add Gate (also GUI)
- Make Shape value small for high speeds
- OPTIMIZE LIMITER
TO DO:
Add RDS control via VST typedef VstIntPtr (VSTCALLBACK *AEffectDispatcherProc) (AEffect* effect, VstInt32 opcode, VstInt32 index, VstIntPtr value, void* ptr, float opt); for Bernd N
Clipper issues Leif / Wolf Stahl (probably the same thing)
Improve Dequantizer by combining data from different block sizes
Add HD delay (upto 10 seconds? Check Matt Aaron's drawing)
PostPosted: Thu Apr 23, 2015 8:24 am
I don't know why I see only this:
Urban Junglist
PostPosted: Thu Apr 23, 2015 10:43 am
Can you send me your settings?
It might be the remaining GUI problem that I mentioned.
Edit: I just fixed that GUI problem, if that's what you're seeing it should be ok in the next build.
PostPosted: Thu Apr 23, 2015 1:54 pm
I had been using beta 021 which had been working fine for me, but then had decided to give the 026 a try to see if I would get the GUI problem like dj_szpajda. Well yes, I did, but today in all fairness decided to load the other versions in between to see if they had that problem and the answer was, yes. The GUI problem started at version 022, and all those up to the current version 027.
At version 021 and prior the items inside the window stretches as needed as you resize the window. At 022 and above, the items inside the window don't reshape properly and freeze so that if you continuing to make the window smaller, it covers up everything inside and then it freezes the GUI. Reshaping the window open again leaves everything white that had been covered up and unless you open the window wide enough before closing, restarting it will only leave it opening to a white window.
PostPosted: Fri Apr 24, 2015 5:56 pm
BETA 761-028
No big changes but I did find a major GUI bug so I hope it fixes the issues that some people have.
Windows stand alone: http://www.stereotool.com/download/ster ... 61-028.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 61-028.exe
VST 32bit: ----://www.stereotool.com/download/vst_stereo_ ... 61-028.dll
- Fixed some more GUI crashes. They should all be fixed now...
- Rewrote all code
- Fixed Ratio
- Added Ratio
TO DO COMPRESSOR:
- OPTIMIZE LIMITER
TO DO:
PostPosted: Fri Apr 24, 2015 6:51 pm
Nope.
8 bands switching MB2 is still freezing.
PostPosted: Sat Apr 25, 2015 1:30 am
BETA 761-029
Found & fixed yet another GUI bug...
Windows stand alone: http://www.stereotool.com/download/ster ... 61-029.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 61-029.exe
VST 32bit: http://www.stereotool.com/download/vst_ ... 61-029.dll
- Rewrote all code
- Fixed Ratio
- Added Ratio
TO DO COMPRESSOR:
- Band Link etc. does not work in 3-band mode, and it should for AGC-type behavior.
- Adjust limiter level for Band Mix
- Fix 'Load default values' question for MB #bands change
- Make Shape value small for high speeds - TO BE DONE: Test if the border value is chosen correctly (shape effect is deminished below 40 ms, reduced to '1' for 0 ms; not sure if 1 is low enough?)
- OPTIMIZE LIMITER
- Maybe add downward expander
- Maybe make 'limit before compress' again
TO DO:
Add HD delay (upto 10 seconds? Check Matt Aaron's drawing). Also finally make resampler for normal output to fix 2 output on different sound cards problem. Move Resample setting from input to output. Let's ignore using 2 inputs for now...
PostPosted: Sat Apr 25, 2015 7:28 am
This time MB2 switching is OK and working , exept the message for "loading default values" everytime pops up even when "No, and don`t ask me again" is pressed.
May be other places with this message to be checked for proper working.
PostPosted: Sun Apr 26, 2015 1:31 am
Pfew, finally! Other issue is now added to the todo list.
