Post new topic  Reply to topic  [ 328 posts ]  Go to page Previous 124 25 26 27 2833 Next
PostPosted: Sat Dec 27, 2014 12:03 am
Another example:
All Ratios = inf:1
Threshold of band 6 and 7 = +12dB
Band 6 has 3-6kHz, Band 7 6-15kHz.
A 4.5kHz tone comes with +24dB.
Band 6 goes down to -12dB.
With all linking = 0 all other bands have 0dB.
Now the Band6 > Band7 Linking is set to 50%.
Band 7 goes down to -6dB.
Now a second tone with 10kHz comes to the first tone.
Its Level is +6dB - No change at all.
Its Level is +12dB - No change at all.
Its Level is +14dB - No change at all.
Its Level is +18dB - No change at all.
Its Level is +20dB - Band 7 goes further down from -6 to -8dB.
And now the linking is set to 0% again - No change at all.
PostPosted: Sat Dec 27, 2014 12:12 am
Well, because of what I said. Anyway, I've implemented that method now too and am running a build now, so in a few hours we can hear what it sounds like.
I've changed the numbering to make the effect decrease with higher numbers:
1. What was called Method 2.
2. What was called Method 1, same as in previous beta.
3. My method 5.
4. What RobertSack just said.
Edit: @RobertSack: Just read your last post, if you say it like that it seems to make sense. But I still think it cannot be good. But we'll see :)
PostPosted: Sat Dec 27, 2014 12:34 am
Wow, wich great christmas gift from you! :-)
So fast, this colors me impressed...
PostPosted: Sat Dec 27, 2014 2:32 am
BETA023: TEST VERSION FOR BAND LINKING METHODS
Windows stand alone: http://www.stereotool.com/download/ster ... 52-023.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 52-023.exe
In the Band Link section under Multiband there's a new Method slider, which can be set to:
  • 1. Difference in dB; the difference in dB between bands will be reduced by set percentage.
  • 2. Difference in %: At a big relative difference the effect is less. Same behavior as previous beta.
  • 3. Locks the coupled band below a point above the source band. (The percentage in the settings is converted to dB's, so 50% = 6 dB).
  • 4. Locks the coupled band below a point relative to the amount of attenuation of the source band. (if a band is at -12 dB with 50% coupling the other cannot get above -6 dB, for -24 that's -12).
4 will cause a different sound at different input levels, the others should not do that.
1 will push the coupled band down the most, 3 the least; 4 depends on the absolute levels so it's impossible to give a statement about its behavior.
Edit: As expected method 1/2 sound better than 3/4 at the same settings ("better" defined as more natural, less sucked-up ultra-highs). Now I'll just wait what you (mainly Robert...) make of this :)
PostPosted: Sat Dec 27, 2014 12:40 pm
Bugs found
Multiband - NAN Output while adjusting the band frequencies
Web Interface - When in password protected mode there is no way of logging in.
My radio station
http://amradio.ddns.net
PostPosted: Sat Dec 27, 2014 6:43 pm
Hans, I hope you can improve the optimized version of phase shaping further.. Un uptomized version is better but the cpu can barely handle it.
The Power of Sound
PostPosted: Sat Dec 27, 2014 7:04 pm
Wow, Method 4 works exactly like expected.
With higher Levels going to the Multiband section the effect is less - hihger band differences are allowed.
I´m still testing...
Regards,
Robert
PostPosted: Sat Dec 27, 2014 7:18 pm
They should be identical - aren't they??? Then please send me your settings for testing!
PostPosted: Sat Dec 27, 2014 7:29 pm
1.. Phase shaping.sts [62.98 KiB]
Downloaded 264 times
SLow fir --> richer and fuller
The Power of Sound
PostPosted: Sat Dec 27, 2014 7:31 pm
Regards,
Robert
But which one sounds better?
