Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2 3
 Post subject: Re: MB2_V773
PostPosted: Sun Sep 20, 2015 9:49 am
@jdave36108, listening to your station the Pulse. Nice sound. Are you still using the same updated preset "MB2"?
It was the old ARVFM stream version, but I listened again to Pulse and I think it's another preset he made, it's none of mine I can tell :)
No it's not, originally i was using ARVFM with some slight adjustments, but i have been recently experimenting with different settings, currently using a modded Expressions V6a, while overnights testing new tweaks to your current presets.
Edit: as of midnight Central US Time, i'm using your new MB2 V773 Fm us75 with clippers, ND turned off
please tune in and let me know how it sounds,
http://thepulsemontgomery.com
(oh, and please like us on facebook.com/thepulsemgm as well!!!)
The Buzz - Central Alabama's Alternative Rock Station
http://thebuzzmontgomery.com
PostPosted: Mon Sep 21, 2015 8:17 am
Here is what i'm using right now, still getting some hissin' with S's, but this V1 of what i'm tweaking on now.
MB2_V773_pulse.sts [78.09 KiB]
Downloaded 478 times
PostPosted: Mon Sep 21, 2015 11:24 am
Sounds softer, but also great, I just tried in the AGC the matrix option with your setting, gives a surprise sound.
Just try it out ;) ok now I'm gonna listen to the stream and like your Pulse page :)
We're getting there with the best sound.
PostPosted: Mon Sep 21, 2015 8:13 pm
I apologize if you tuned in to dead air, most of this morning i had a power outage around 10:30 central US time, just now back up and running.
You're right, turning on the matrix mode does give it a nice surprise, though I'm pleased with the sound as it is now.
PostPosted: Wed May 18, 2016 10:20 am
[edited]
New HD preset in first post...
Changed 2 band AGC to three bands (because for better siblings protection)
Added True Bass in the audio path, between multibands.
Added limiters in high section from multiband 2, to get more control of "ssss" sounds. (just let me know if you like this or not please)
Bass Boost is set to boost up from 0 to 25 Hz to get that extra deep low (only when you listen to a good stereo gig)
Removed the de-esser, because there is enough control of highs in AGC and Multiband 2
End path (Output) is lowered to -0.05dB because this preset kicks pretty hard in,
Enjoy and feedback is always welcome
