Post new topic  Reply to topic  [ 387 posts ]  Go to page Previous 1 2 3 4 539 Next
PostPosted: Fri Feb 17, 2012 5:14 pm
the new AGC filter is just great !!!!!!! what was needed for a true leveling.
Hans, keep it up ..... this is the golden path!
Ps. sorry for my terrible english :oops:
Luca
http://www.radioenergy.to
PostPosted: Sat Feb 18, 2012 2:25 am
BS412 silence issue in stand alone version is fixed
And a nice surprise in the scope :)
Stand alone: http://www.stereotool.com/download/ster ... 22-013.exe
DSP: http://www.stereotool.com/download/dsp_ ... 22-013.exe
PostPosted: Sat Feb 18, 2012 3:03 am
ok, i'll change my avatar. Image
PostPosted: Sat Feb 18, 2012 6:40 am
Damn!
This means that now I have to buy (again) LSD instead to create similiar psychological effects as with the old scope !
PostPosted: Sat Feb 18, 2012 8:44 am
Hans, there's something I didn't completely understand about the filter 'Up-Push Strength Near Minimum Reduction' in AGC section.
If set to a value > 1 say - 3.0 and if the AGC is operating in 3 band mode, I see only the first 2 bands rushing faster in silent passages. Not the 3rd band. Why?
Also, please make the VST plugin save the value for this plugin when set to anything > 1. I have requested this before several times, possibly no one finds it important. :roll:
visit website
PostPosted: Sat Feb 18, 2012 9:25 am
VST !!!!????? :o
http://www.kanal80.net
Best 80's & 90's Music
PostPosted: Sat Feb 18, 2012 10:27 am
Damn!
Specially for you there are new effects but it takes a bit more work. It happens if you manual resize the screen horizontally.
PostPosted: Sat Feb 18, 2012 12:54 pm
dank je :D
PostPosted: Sun Feb 19, 2012 2:22 am
It would be great and much more valuable for analyses if the scope would have an additional time axis scaling option:
:arrow:
viewtopic.php?f=16&t=4106
PostPosted: Sun Feb 19, 2012 5:56 pm
Here's the first official 6.22 beta version.
Changes:
- Added a much better filter than before that removes sudden spikes which get past the AGC. (See the AGC panel).
Great! It's works damn Good! It's reduce "volume burst" (on songs like Foo Fighters - The Pretender) to minimum when you use my profile LUCIDITY FX5... so i preprare it for update :-)
The new scopes is nice, but might be better to change their orientation to like this: http://i.imgur.com/Wrs2n.jpg
