Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Jul 18, 2020 5:14 am
Other bug, when I turn off the stream (Streaming Output section)...
https://fmfeeling.com
PostPosted: Sat Jul 18, 2020 9:05 am
Hm. These last 2 are scary. I checked both of them, and there's nothing that changed in the code since version 9.50 that explains these. So they might not be new (?). Just for clarity: The silence was just a lack of a playlist, Stereo Tool itself just kept running normally despite showing this message?
We have already released version 9.52 because there was a clipper bug that could cause a really bad sound in some situations (combination of settings).
@Studio 11: Keep an eye out for the next beta post, we have a new bass enhancer that makes the bass far more consistent.
PostPosted: Sat Jul 18, 2020 2:26 pm
Correct - actual input was available but no audio present (player stopped). As soon as I moved my mouse to Stereo Tool it popped up with the no audio warning popups. Acknowledged them, grabbed the error info to pass on and then started the audio input again.
Rossco
PostPosted: Mon Jul 20, 2020 10:14 pm
hvz,
The VST 64 bit links for 9.52-002 BETA give me a 404 error. Can you please fix them?
Thanks
PostPosted: Mon Jul 20, 2020 10:23 pm
Hans, in the notes for release 9.52, you call out new version of Declipper. Where are you posting that for download? The declipper.com site is still way outdated. It'd be cool if that was either updated or taken down and then declipper added to your main download page, under WatchCat, or something.
Thanks
PostPosted: Tue Jul 21, 2020 9:49 am
Here's the link to the latest version of perfect declipper. https://www.stereotool.com/download/vst ... lipper.dll
Still shows as 3.02 July 2019 in the ABOUT box. So I don't know if it's final.
I no longer get the exception when using CTRL to adjust bars, however.
PostPosted: Tue Jul 21, 2020 11:23 am
O. Crap. I must have forgotten to update that. Beside that, yes this should be the new release. I'll do a rebuild soon with the correct version number and upload it - for now just use this version.
PostPosted: Wed Jul 22, 2020 3:52 am
Hi Hans, when will a better bass enhancer be added?
PostPosted: Thu Jul 23, 2020 6:25 pm
finally this 9.52 sounds very good, the high frequencies are back to being heard, stereo separation very coherent and natural ...
I am a little frustrated that with each version the sound changes considerably, but it is the price to pay for having constant updates.
tnx
Edit:
news on the release of Stx on the market?
PostPosted: Fri Jul 24, 2020 3:17 am
Yes, ST does not have enough bass filters, we need few more.
