Post new topic  Reply to topic  [ 209 posts ]  Go to page Previous 117 18 19 20 21 Next
PostPosted: Fri Sep 01, 2017 8:00 am
8.41 BETA053.
Windows stand alone: https://www.stereotool.com/download/ste ... 41-053.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 41-053.exe
VST: https://www.stereotool.com/download/vst ... 41-053.dll
- Old web interface: Fix display of vu meters, also for SC
- Old web interface: Text color in check boxes and buttons doesn't update
- Weird RDS crash appears to be back. Now in SST. Still only in release mode.
- SST: Update help Done for now, more documentation for new stuff needed.
- Clipper was re-calculating pre-emphasis curves constantly when outputting both pre-emhpasized and separately processed audio.
- Linux version sometimes GUI doesn't open - retry internally?? -> Apparently a known bug, using the same workaround now that Chromium uses.
- Linux version doesn't exit.
- MicroMPX check feature 1 vs 2 (no error shown!)
- Check MicroMPX and Stereo Tool with Valgrind.
- Change version number
- Linux version crashes in latest Debian (Jack compatibility issue?) -> Not here. Will retest when new build is ready.
- .sbr file errors in generic_stereo_tool debug -> Deleting DEBUG folder fixed it - rebuild did not!
- Kill ProppFrexx logging!
- Integrated MicroMPX in something.
- Old web interface avoid reload OR pass GUID. Right now top presets list is flashing.
- Old web interface: Original right load can be messy. Load left first? -> No load logo page first
- Old web interface: Fix left display
- Old web interface: Don't set default selection.
- Wide display: Make meter section wider
- Fix build warnings
- Reported sound card buffer overruns pthompson -> Not fixed, Windows 10 update broken VAC driver.....
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes.
- Stereo Image was broken in BETA049
- Name "Spectrum Controller" -> Rename? DONE, now called Auto EQ
- FM Demodulator reported to be broken (must be the compiler switch again... grrr.... -> No, was caused by change in IPP!
- AM clipper is now always oversampled
- Allow moving equalizer between MB's
- Allow moving BB before last MB
- SST: Couple Hard Limit to clipper on/off
- SST: QoS dynamic DLL -> Werkt, maar QoS niet??
- SST: Network: Add "Interface" selection. Also priority?
- SST: Add Stereo Image phase filter - somewhere. Under AZIMUTH (rename it to Phase or something)
- SST: C-QUAM divide by 2 issue
- SST: Bass Boost: Relax limits on frequencies
- GUI doesn't work in some of the versions of 046
- Disable Pre Limiter display in limiting mode.
- Share PEQ, attack/release?
- Move Spectrum Control and new AGC out of "Experimental" tab, and allow licensing. --> Button to buy it will be added to the website on Monday!
- Show Spectrum Control and new AGC in bottom display
- Optimize limiter
- Allow using bass distortion in bass clipper when used for final limiter.
- Limiter display freeze
- Add pre-AGC classical music thing
- MicroMPX add display for packet reception todo add reset packets, fix timing, show current playing position
- Add "Advanced Dynamics" to license overview screen
- Finish pre-AGC classical music thing
- SST: Make list of new ID's
- 64 bit Hard Limit is working again
- Meter for Limiter is no longer frozen.
- 9sg - update to latest code
- Old web interface bug fixes
- 9sg 1 thread.
- Add bass clipper + final limiter for testing for streaming, to figure out once and for all if it's useful or not.
- Final limiter: Make speed depend on amount of bass clipping.
- Final limiter: Fix going though chunks.
- Spectrum Control: Abrupt Change Protection could overract because it ignored certain settings.
- Spectrum Control: ACP can overreact!
- Spectrum Control: Why is kick so fast?
- All compressors: Attack/release behavior in the new RMS mode was wrong, now fixed. Result is more consistent and movements are less sudden.
- Compressor inverse-Covfefe
- AM stereo downmixer 9
- Show backup input is active - change color of input level meters
- Final limiter: Put in separate file, so I can test it separately.
- Final limiter: Make own settings page. Lots of settings needed...
- Final limiter: Make it work for Quality != 100%, Latency != 4096
- MicroMPX web interface
- Fixed crash when changing number of bands in Spectrum Control.
- Add Parametric EQ to AGC 2
- RDS: 8 character words with <| go wrong
- RDS: Empty fields - remove?
New "Experimental" section, containing:
* NEW AGC
* New Spectrum Controller (replacement of Power Bass/Power Highs), adjusts the spectrum BEFORE the AGC, without affecting dynamics or loudness.
The Analog compressors now have new "Max ratio" and "Max ratio at" settings to have dynamic ratio's depending on how the amount of attenuation.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- ACP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- SC ACP: Speeds should not affect it!
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- Add new presets!
ST:
- Remove a bunch of presets
- 64 bit Pi build
- Update Wes' and Paul's preset
- 9 memory usage First bit done
- MAC build
- NAB! LW!
SST/MicroMPX:
- MicroMPX Linux: Directory reading logging
- MicroMPX: Add built-in help
- MicroMPX Pi 64 bit: Build warnings
- Mu character in SST
- MicroMPX: Log directory must end at .log, not .ini (Windows)
- MicroMPX: Green color for eq
- SST: Rename Auto EQ Koek
- SST Quality > 100% crash -> Again a compiler bug!
- SST: Ohio Valley and Blue Steel use Pre Amp
- MicroMPX web interface version: Make sure that all ranges are correct and everything is stable when changing settings. -> Mathijs & Matthijs - sent
- MicroMPX sample rate bug
- ProppFrexx reported crash Version with extra logging sent
- NAN? Doesn't reproduce, postpone for now
- WatchCat MAC installer.
- 9 memory usage
- New Stokkemask idea
- _CrtSetAllocHook(AllocHook);
- ladspa? r.co (Also AU & ProTools)
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Optimize Spectrum Control and AGC 2
- Update RDS encoder to Mathijs' filter.
- ADYEN
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- RDS: Make note in help about shared drives. Also send to Omnia.
- Try new stereo widener idea
- SST: Make it switch to backup input when the normal/FM signal switches.
- Make compressor with alternative ratio implementation
- Test clipping
- Improve UECP ASCII mode for Magic RDS (just handle \n's inside strings)
- RDS UCEP: Put a timeout on the fallback to default settings. Some programs close the connection immediately.
PostPosted: Fri Sep 01, 2017 2:22 pm
Have updated VAC driver and added 100ms buffer. ST now stable in win 10.
PostPosted: Fri Sep 01, 2017 2:44 pm
Loaded Breaking Dreams from in gui... and error.
PostPosted: Fri Sep 01, 2017 3:09 pm
Just saw that too. Turns out that there were a few settings that are only available in debug mode, and I was trying to set those in release mode. Fixed (next beta). I'll also put in your updated preset.
PostPosted: Sat Sep 02, 2017 6:31 am
May have spoken too soon. Come back this morning and see a buffer overrun popup window. Humm...
Is anyone else experiencing similar issues?
PostPosted: Mon Sep 04, 2017 1:45 am
Even though it's not listed anywhere I can find, you'll have to update your minimum computer specs. for the new versions from here on.
At home on my build computer, I'm running windows 7 using winamp with 4GB RAM & Intel i5 M43@2.27GHz CPU.
In version ST 8.40, my settings run 7 threads at average 26.4% time in processing & 13.5% time in GUI, with Winamp using average 73% CPU at 110% max frequency. 42% total physical RAM usage.
In version ST 8.41 beta 053, the same settings run a bit higher, but still, well within reason.
Turn on auto EQ, & it almost doubles the 7 threads to 40-55% time in processing & 32-50% time in GUI, with Winamp using average 89% CPU at 111% max frequency. 42% total physical RAM usage.
The new AGC also uses significantly more CPU than the old one.
If you want to add a few of the new settings together, it can quickly push the CPU to the limits.
My new settings that I want to use, push the 7 threads to 98% time in processing & tops out around 57% of time in GUI, running Winamp at average 96% CPU at 111% max frequency. 43% total physical RAM usage & the FM transmitter output audio becomes glitchy/breaks up.
This is all running the same piece of music through Winamp/Stereo Tool.
Looks like I'll have to invest in a new more powerful computer at home, to continue my builds on.
pthompson3 how far can I push our processor?
PostPosted: Mon Sep 04, 2017 1:56 am
There are several things that I want to do to improve the performance again, but that will not yet be ready in the upcoming release.
The CPU load that you're describing seems higher than I would expect though. Will look up the CPU tomorrow...
PostPosted: Mon Sep 04, 2017 10:34 am
InPhase, not too sure who you are, Im guessing. The BCL406 are equipped with a blast furnace CPU (i7 4Ghz). I truly cannot see you even coming close to using even 40% of the available processing power for ST with everything turned flatout.
There are ways to back off the CPU use gentle without too much of a impact. However, as more features in ST come into play, then unfortunately you do need several cores and importantly, plain old clock grunt to get around and perform the mathematics thats been requested by the application.
PostPosted: Mon Sep 04, 2017 10:46 am
I don't see an M43 listed in https://www.cpubenchmark.net/cpu_list.php , is that really the exact model number?
PostPosted: Mon Sep 04, 2017 11:50 am
Yes that's what windows lists it as, it's quite possibly this one? https://www.cpubenchmark.net/cpu_lookup ... GHz&id=775
