Post new topic  Reply to topic  [ 209 posts ]  Go to page Previous 116 17 18 19 20 21 Next
PostPosted: Thu Aug 24, 2017 12:56 am
Except for the 64 bit VST (which is still building), the other binaries are updated to 8.41 BETA050 now.
PostPosted: Thu Aug 24, 2017 1:08 am
@steff007
Thank you brother! ;)
PostPosted: Fri Aug 25, 2017 2:38 pm
Since 047, I'm having the odd buffer overrun... out to VAC on FM... No pattern.. random..
Still occuring on 050.
Just thought I should mention it...
PostPosted: Fri Aug 25, 2017 2:52 pm
Something has changed here too. When I reopen my laptop I get beeping and a message that my output rate is not supported. Restarting ST fixes it. Got this behavior on several betas while you where integrating Port audio, then it cleared up. Using VB cables @192K. Does it when ST is in bypass.
PostPosted: Fri Aug 25, 2017 2:55 pm
When I was integrating PortAudio is ages ago..... I haven't changed anything recently....... (Just checked: Haven't touched it since June!). Could it be a Windows update?
PostPosted: Fri Aug 25, 2017 3:31 pm
It's not a major issue for me. Could be a Windows update. If I isolate it, I'll let you know.
PostPosted: Fri Aug 25, 2017 3:33 pm
It absolutely could be a Windows update. One of my machines (not on air), recently got Creator's. It has destroyed the audio subsystem. Windows constantly deciding that my preferred communications device should be something other than what I set...etc. The new update is a disaster for audio.
PostPosted: Sat Aug 26, 2017 12:39 pm
Funny, exactly the same behavior there are also regularly here for Windows updates. Sometimes even the entire sound card is uninstalled. Mostly everything is fine after a reboot but that is very annoying.
PostPosted: Sun Aug 27, 2017 6:52 am
Just further on this, I have discovered that the latest Win 10 update has indeed changed what I am assuming is a kernel resource, with VAC 414 running out of buffers when set to 50ms. Have increased to 100ms, but no avail. Looked at the driver and found version 4.14 running. Have upgraded to 4.15 and the issue is better, still some starvation of the buffer in stereo tool showing, but not as much. Initially is looks OK with 4.15.
PostPosted: Sun Aug 27, 2017 12:49 pm
8.41 BETA052.
Windows stand alone: https://www.stereotool.com/download/ste ... 41-052.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 41-052.exe
VST: https://www.stereotool.com/download/vst ... 41-052.dll
- Integrated MicroMPX in something.
- Old web interface avoid reload OR pass GUID. Right now top presets list is flashing.
- Old web interface: Original right load can be messy. Load left first? -> No load logo page first
- Old web interface: Fix left display
- Old web interface: Don't set default selection.
- Wide display: Make meter section wider
- Fix build warnings
- Reported sound card buffer overruns pthompson -> Not fixed, Windows 10 update broken VAC driver.....
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes.
- Stereo Image was broken in BETA049
- Name "Spectrum Controller" -> Rename? DONE, now called Auto EQ
- FM Demodulator reported to be broken (must be the compiler switch again... grrr.... -> No, was caused by change in IPP!
- AM clipper is now always oversampled
- Allow moving equalizer between MB's
- Allow moving BB before last MB
- SST: Couple Hard Limit to clipper on/off
- SST: QoS dynamic DLL -> Werkt, maar QoS niet??
- SST: Network: Add "Interface" selection. Also priority?
- SST: Add Stereo Image phase filter - somewhere. Under AZIMUTH (rename it to Phase or something)
- SST: C-QUAM divide by 2 issue
- SST: Bass Boost: Relax limits on frequencies
- GUI doesn't work in some of the versions of 046
- Disable Pre Limiter display in limiting mode.
- Share PEQ, attack/release?
- Move Spectrum Control and new AGC out of "Experimental" tab, and allow licensing. --> Button to buy it will be added to the website on Monday!
- Show Spectrum Control and new AGC in bottom display
- Optimize limiter
- Allow using bass distortion in bass clipper when used for final limiter.
- Limiter display freeze
- Add pre-AGC classical music thing
- MicroMPX add display for packet reception todo add reset packets, fix timing, show current playing position
- Add "Advanced Dynamics" to license overview screen
- Finish pre-AGC classical music thing
- SST: Make list of new ID's
- 64 bit Hard Limit is working again
- Meter for Limiter is no longer frozen.
- 9sg - update to latest code
- Old web interface bug fixes
- 9sg 1 thread.
- Add bass clipper + final limiter for testing for streaming, to figure out once and for all if it's useful or not.
- Final limiter: Make speed depend on amount of bass clipping.
- Final limiter: Fix going though chunks.
- Spectrum Control: Abrupt Change Protection could overract because it ignored certain settings.
- Spectrum Control: ACP can overreact!
- Spectrum Control: Why is kick so fast?
- All compressors: Attack/release behavior in the new RMS mode was wrong, now fixed. Result is more consistent and movements are less sudden.
- Compressor inverse-Covfefe
- AM stereo downmixer 9
- Show backup input is active - change color of input level meters
- Final limiter: Put in separate file, so I can test it separately.
- Final limiter: Make own settings page. Lots of settings needed...
- Final limiter: Make it work for Quality != 100%, Latency != 4096
- MicroMPX web interface
- Fixed crash when changing number of bands in Spectrum Control.
- Add Parametric EQ to AGC 2
- RDS: 8 character words with <| go wrong
- RDS: Empty fields - remove?
New "Experimental" section, containing:
* NEW AGC
* New Spectrum Controller (replacement of Power Bass/Power Highs), adjusts the spectrum BEFORE the AGC, without affecting dynamics or loudness.
The Analog compressors now have new "Max ratio" and "Max ratio at" settings to have dynamic ratio's depending on how the amount of attenuation.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- ACP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- SC ACP: Speeds should not affect it!
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- Old web interface: Fix display of vu meters, also for SC
- Old web interface: Text color in check boxes and buttons doesn't update
- AutoEQ filmpje
- Weird RDS crash appears to be back. Now in SST. Still only in release mode.
- SST: Update help Done for now, more documentation for new stuff needed.
- Clipper was re-calculating pre-emphasis curves constantly when outputting both pre-emhpasized and separately processed audio.
- Linux version sometimes GUI doesn't open - retry internally?? -> Apparently a known bug, using the same workaround now that Chromium uses.
- Linux version doesn't exit.
- MicroMPX check feature 1 vs 2 (no error shown!)
- Check MicroMPX and Stereo Tool with Valgrind.
- Change version number
- Linux version crashes in latest Debian (Jack compatibility issue?) -> Not here. Will retest when new build is ready.
- .sbr file errors in generic_stereo_tool debug -> Deleting DEBUG folder fixed it - rebuild did not!
- Kill ProppFrexx logging!
ST:
- ProppFrexx reported crash Version with extra logging sent
- Add new presets!
- Remove a bunch of presets
- NAB! LW!
- 64 bit Pi build
SST/MicroMPX:
- MicroMPX web interface version: Make sure that all ranges are correct and everything is stable when changing settings. -> Mathijs & Matthijs - sent
- SST: Rename Auto EQ Koek
- MicroMPX: Add built-in help
- Mu character in SST
- SST: Ohio Valley and Blue Steel use Pre Amp
- _CrtSetAllocHook(AllocHook);
- ladspa? r.co (Also AU & ProTools)
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Optimize Spectrum Control and AGC 2
- Update RDS encoder to Mathijs' filter.
- ADYEN
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- RDS: Make note in help about shared drives. Also send to Omnia.
- Try new stereo widener idea
- SST: Make it switch to backup input when the normal/FM signal switches.
- Make compressor with alternative ratio implementation
- Test clipping
- Improve UECP ASCII mode for Magic RDS (just handle \n's inside strings)
- RDS UCEP: Put a timeout on the fallback to default settings. Some programs close the connection immediately.
