Post new topic  Reply to topic  [ 299 posts ]  Go to page Previous 115 16 17 18 1930 Next
PostPosted: Sun Apr 21, 2013 7:47 pm
AMD X4 9950 = No Way!
:( :( :( Stop laughing :P
PostPosted: Sun Apr 21, 2013 9:50 pm
Thx, now I know :)
I'd like to now how "take some shortcuts" and "take oversampling shortcast" affect sound :)
"take some.." default is on but description "reduces quality"?
Ah, "some shortcuts" is similar to the Quality slider - but at a smaller scale. It does cause some artifacts in some rare cases.
"Oversampling shortcuts" - clipping should be done at 4x oversampling to catch all the spikes. With this enabled, part of the clipping is done at only 2x oversampling. No quality effect, but it might leave bigger spikes through.
PostPosted: Mon Apr 22, 2013 3:36 pm
Composite Clipper and SSB running on a Q6600 Intel machine (core2quad). As long as cpu quality is set below 50%, no dropouts, exceeding 50%, dropouts. SSB working, as well, can't take more exacting measurements yet, Didn't notice any audible difference in the separation with SSB turned ON (probably optimal mode). Composite Clipper definitely puts more "air" in the HF.
I did notice the output flashing RED occasionally. Is this expected behavior?
cpu 1-60%
cpu2-15 to 20%
cpu3-80%
cpu4-15 to 20%
(running with quality at 50%)...can't go over 50% or dropouts occur.
Nice job Hans!
PostPosted: Mon Apr 22, 2013 7:27 pm
Do you use that with XP ?
Try to set affinity for ST to 2 cores.
Also i know that 'that' cpu easy works at 3GHz.. will help alot (with proper cooling).
PostPosted: Mon Apr 22, 2013 8:21 pm
right now using XP Service Pack 3.
I'm not sure where you set the affinity for stereo tool do you mean multi-core? if so, it is enabled.
Many thanks...is there an upgraded or newer Radium preset, btw? nice work!
PostPosted: Mon Apr 22, 2013 8:56 pm
Affinity in Task Manager.. Go to Processes, Right click on StereoTool.exe > affinity > select 2 cores. You will see that all 4 are used.
PostPosted: Mon Apr 22, 2013 9:36 pm
Got it! Thanks for the clarification. Many thanks!
Best to you!
PostPosted: Mon Apr 22, 2013 9:39 pm
Any idea what can be causing the output to flash red? I haven't checked total mean deviation, yet on a monitor. One might assume that it is exceeding?
PostPosted: Mon Apr 22, 2013 9:59 pm
I can get CPU quality with clipper ON up to about 75% now, so thanks for the advice! That's some clean composite clipping!!!!!!!!!
PostPosted: Mon Apr 22, 2013 10:14 pm
Ok that proves what i said erlier, that Affinity need to be added in ST. :)
