Post new topic  Reply to topic  [ 433 posts ]  Go to page Previous 114 15 16 17 1844 Next
PostPosted: Mon Sep 29, 2014 9:33 pm
PostPosted: Mon Sep 29, 2014 9:44 pm
Yes , thank you
But i`m telling you that time is running normal . The CPU is far away from the 100% and still time is running as real time.. nevermind what preset i set . Even with mine that is very simple one ...
I`m talking about for the time of the song showed in winamp . I guess that time must scroll faster with that type of processing , right ?
Also i`m having normal ouput from the ST and can listen to it again normally from the FM output... I just don`t get it .
PostPosted: Mon Sep 29, 2014 9:46 pm
whaaaa im green :D
PostPosted: Mon Sep 29, 2014 9:59 pm
I ran tests as suggested, track length 5:53, format WAV 44.1kHz.
CPU used was Intel i5-660. OS Win7 x64.
Preset Thorium6 (soft)
Oldest ran 1:22, Old with new 1:21, and latest 1:20. So every steps decreases processing time roughly by 1 second.
PostPosted: Mon Sep 29, 2014 10:06 pm
It seems it really works better on newer CPUs and on older usually slightly worse. Also there is diff between AMD and Intel.
PostPosted: Mon Sep 29, 2014 10:08 pm
I could run ST FINE restart the system and have problems and then restart again and it was fine strange..... But it is an old install of windows 7. I am getting ready for moving out of 7 and run a clean install of 8.1 on a ssd and do more testing of corse)
You might want to try the next version - I haven't enabled the CPU affinity settings yet (I have a test version here myself where it works) - could very well be that affinity was set differently which might cause differences in behavior. If you set the affinity yourself it should be always the same.
PostPosted: Tue Sep 30, 2014 9:55 am
Bojcha
is this good too ?
PostPosted: Tue Sep 30, 2014 1:39 pm
waiting for new stereotool output sound better :D
#### stereotool is the best broadcast audio prossesing in the world ;) ####
PostPosted: Tue Sep 30, 2014 2:34 pm
Yup. It works better on newer Intels and on all AMD's apparently. And slightly less good on older Intels. Unfortunately there are quite a lot of those...
I'll browse through the compiler settings again to see if I missed anything. At this point an improvement of just a few percent would suffice to ditch the old compiler.
PostPosted: Tue Sep 30, 2014 5:23 pm
Wooh! If I enable all the new optimizations for i3/5/7 processors, I can run a complete FM preset including composite clipper and even Stokkemask with a CPU load of 10%! (CPU: i7-4770S). Without Stokkemask 7%! Streaming preset 2%.
For those of use who use Intel i7 4770K or 4790K systems this type of CPU load figure is excellent news.
Is there a chance there could be a build for those CPUs to allow a machine to run an FM and a Stream version at the same time and still keep the machine just happily working away under so little load?
C.
