Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 155 posts ]  Go to page Previous 19 10 11 12 1316 Next
PostPosted: Sat Sep 08, 2018 11:55 pm
Stereo Tool 9.03 BETA018
Windows stand alone: https://www.stereotool.com/download/ste ... 03-018.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-018.exe
VST: http://www.stereotool.com/download/vst_ ... 03-018.dll
VST: https://www.stereotool.com/download/vst ... 03-018.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-018.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-018.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-018.exe
Windows libsndfile-1.dll (needed for MicroMPX decoder and command line version, place in same directory): MicroMPX command line enc/dec: https://www.stereotool.com/download/libsndfile-1.dll
  • Bug fix: Dehummer had a crackle since version 014. That's back to normal again now.
  • Test MicroMPX with Stokkemask - 0.5 dB -> Changing setting in Stereo Tool helps
  • Show a warning if Quality it not set to 150% for Latency 128 and 256.
  • Bass Clipper sounds horrible at 128, True Bass at 128 and 256 -> disabled.
  • Update Dutch Moose
  • Clipper: Bass section lowpass freqs should not be too close at latency 512, 256, 128. (Noticeable in Dutch Moose preset)
  • Check that The BIMP works, maybe add parametric eq
  • MicroMPX rate limiter
  • 192 kHz input is broken! Output is mono, something is going wrong
  • SST ID's
  • Crackle in 2nd PDF track -> Improved
  • Allow lower latency (6 ms, 9 ms)
  • Improve clipper sound 1-6 kHz area
  • License The BIMP
  • Updated Paul Thompson's and Bojcha's presets
  • Updated Dutch Moose preset (more highs. less deep bass, less stereo widening, sounds much cleaner)
  • Stok: Lower samplerates look less good (and that makes no sense test without LOWER) -> 44.1 is ok now (-0.01 dB), 40 kHz is clearly lower (-0.20 dB), still way better than before (it was more than -0.40 dB in 9.02).
  • Add MicroMPX plugin licensing [22]
  • Fix Pi build (Stokkemask NEON code)
  • Update LogInOut code
  • New Stokkemask mode now works well in all Strictness settings above 7 (below 7 it's not very strict)
  • Stok: Post filter caused NANs
  • Stok: Move start point to later stage? (TUESDAY)
  • Cleanup code for VST3 David
  • Turn BIMP *OFF*
  • DrawWave draws outside of screen in FM analyzer (TUESDAY) - apparently ok
  • Include MicroMPX - for real now [22]
  • Hide Matrix Stereo for now
  • Stok: Add post filter
  • Stok: Legacy CPU load back to that of 9.02
  • API: Audio signal VU meter, info about whether stream is good NOW.
  • Started with matrix-based stereo widener; not happy yet.
  • Stokkemask NAN and other exceptions solved. (from previous beta)
  • Stokkemask threading issue solved. (from previous beta)
  • Stok: Remove overlap shortcut for stricter result (increases CPU).
  • Stok: Measure mask in every stage for stricter result (increases CPU).
  • Stok: Apply measured results in every stage for stricter result (increases CPU).
  • Stok: Replace L-R reduction in final stages by total volume reduction.
  • Stok: Figure out how to adjust shape at different sample rates -> Found correct Gaussian window sigma value instead, applied for both processing and display (which were set differently before!)
  • Stok: Replace "Looseness (sounds better)" by something that moves the mask up and down.
  • Stok: 1e stage only inner
  • Stok: More steps at end, needs to be both tighter and have less effect (is that last thing still needed???)
  • Stok: Try reducing the audio level in the final stage - lowering highs has proven useless at that point. --> SEEMS TO WORK, but only do this as the last stage!
  • MicroMPX SWEEP
  • Fixed a crash in the "Limit instead" code (Advanced Clipper).
  • Removed (moved to Extreme Tweaker for possible future testing) some Stokkemask settings that had a bad effect on compliance. Good settings are 50% / 30% / 40 dB (without the 40 dB it should be fne too, but there's a bigger chance at overshoots at the bottom of the mask. 100% for the first value increases overshoots!!!!! 39 and 38 should be safe as well - but I haven't had time to measure those separately anymore. Anyway in the older versions this value was set to 0....... Setting it higher may cause an audio quality reduction.
  • Crash fixed
  • Stokkemask: Try I/Q Clipper mode, highs are coming out slightly too loud, due to LPF? Might be good enough... -> Idea doesn't work
  • Stokkemask: We don't care about CPU load, try adding more stages -> No effect
  • Stokkemask: Default back to 50% for safety - that way we don't have to worry about breaking older versions. And we still get 90% of the improvement that way.
  • More experimental stokkemask settings added.
  • Stokkemask: Improved further (looks about equally strict, but I can squeeze over 1 dB more anti-phase content through than with 9.02). NOTE: SETTINGS ARE DEFAULTING TO 9.02 BEHAVIOR BECAUSE I DON'T KNOW YET IF THE SIGNAL IS EQUALLY STRICT, AND I DON'T WANT SOMEONE TO GET FINED FOR HAVING STOKKEMASK OVERSHOOTS. To get the new behavior, set "New looseness 1" higher (50% should definitely be safe, I'm not sure about 100%), "New looseness 2" to 30%, and "Side level" to 40.
  • Improved Stokkemask - output is stricter (closer to the mask), so it has less impact on stereo separation. (*)
  • Memory usage reduced by about 12 MB
    PLANNED:
  • Add MicroMPX decoder abonneer-IP
  • Fri: SST/uMPX interface
  • The BIMP on LQLL
  • Coins
  • Add Kantar support BUSY
  • Linux multiple instances
  • RDS urgent issue
  • Cntrct IN
  • Test preset that causes buffer to run empty - why? --> Settings issue, maybe add a popup for this situation (buffer is slowly filling up or running empty)...
  • RDS: Support for AF method B
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
  • uMPX decoder: Add multicast subscribe
New vs old Stokkemask measurement numbers, relative to 48 kHz no stokkemask, for audio with quite extreme stereo. Numbers are L-R loudness, L loudness
Freq     old/new          L-R    L
48   kHz no  Stokkemask:  0.00,  0.00 (reference)
48   kHz new Stokkemask: -0.62, -0.27 (0.46, 0.10 better than old!)
44.1 kHz new Stokkemask: -0.63, -0.22 (0.54, 0.11 better than old!)
40   kHz new Stokkemask: -0.82, -0.29 (0.65, 0.14 better than old!)
48   kHz old Stokkemask: -1.08, -0.37
44.1 kHz old Stokkemask: -1.17, -0.33
40   kHz old Stokkemask: -1.47, -0.43
PostPosted: Sat Sep 08, 2018 11:57 pm
- the goal is to mixing the microphone input from SCA with line input. You don't have separate output for microphone processing ? So we don't use Insert of the mixing table ? In this case when dj talk, the need to listen ST output and not output of mixing table ?
Yes. If you go out and then back in, you get extra latency. The way it's now, you don't.
- We use normal output, not LQ LOw Latency with BIMP ? in this case we need to configure 'CPY & Latency' to 256 samples and 'Buffer size' of Normal output to 0 sec ? to have the minimum latency for the BIMP ?
I haven't had time yet to put it in Low Latency mode but I will. Once that's done you can listen to either, and the audio that comes out will contain both microphone and normal audio.
I have made test and indeed the microphone sound good, but I have again latency.
In the past I had made test with a specific instance of ST for microphone with LQ Low Latency and I had less latency
See the new latency settings. You can now go down to 128 samples, which is as low as the LQ Low Latency output. This will of course come at a cost (in audio quality).
PostPosted: Sun Sep 09, 2018 5:42 am
What about the noise in declipper? That was in the ToDo list a bit ago. Can't recall any details.
PostPosted: Tue Sep 11, 2018 12:02 pm
Stereo Tool 9.03 BETA020
Windows stand alone: https://www.stereotool.com/download/ste ... 03-020.exe
Winamp DSP: ---.stereotool.com/download/dsp_stereo_tool_installer_BETA903-020.exe FAILED
VST: http://www.stereotool.com/download/vst_ ... 03-020.dll
VST: https://www.stereotool.com/download/vst ... 03-020.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-020.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-020.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-020.exe
  • Added PFD preset (literally dozens of people requested that). Still need to change the name, it's the 2nd Dutch Moose in the list (the name is too long, so I'll rename it to just PFD 2018)
  • The BIMP on LQLL
  • SST ID's
  • License The BIMP
  • Turn BIMP *OFF*
  • MicroMPX SWEEP
  • Crash fixed
    PLANNED:
  • RDS urgent issue
  • Cntrct IN
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
Freq     old/new          L-R    L
PostPosted: Tue Sep 11, 2018 6:41 pm
hopefully this message is not posted twice but my problem is that since beta version 16 I have a non-working interface. An empty frame. I use the standalone 64 bit version on windows7. Does anyone also have this problem?
PostPosted: Tue Sep 11, 2018 8:26 pm
Can you send me your settings (in a PM)? Also please tell me whether you have a 4K screen or not.
I have changed some things in the left menu which did this a few versions ago because it was drawing outside of the window - but it shouldn't be the case anymore in the last 2 beta's.
PostPosted: Tue Sep 11, 2018 10:02 pm
Hans, the link for the Winamp DSP BETA903-020 has failed. Please can you resend it?
PostPosted: Tue Sep 11, 2018 11:31 pm
I use standalone but 32bit on Win7 64bin. It's all fine there.
PostPosted: Wed Sep 12, 2018 12:10 am
The build failed because my harddisk was full. New build is running now.
PostPosted: Wed Sep 12, 2018 10:42 am
Stereo Tool 9.03 BETA021
Windows stand alone: https://www.stereotool.com/download/ste ... 03-021.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-021.exe
VST: http://www.stereotool.com/download/vst_ ... 03-021.dll
VST: https://www.stereotool.com/download/vst ... 03-021.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-021.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-021.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-021.exe
  • The BIMP on LQLL
  • SST ID's
  • License The BIMP
  • Turn BIMP *OFF*
  • MicroMPX SWEEP
  • Crash fixed
    PLANNED:
  • Fix GUI crash in 915x577 screen size on non-4K screens.
  • Put something on I/O page (it's empty now)
  • Put Dutch Moose and PFD presets in SST
  • Release
  • RDS urgent issue
  • Cntrct IN
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
Freq     old/new          L-R    L
