Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 155 posts ]  Go to page 1 2 3 4 516 Next
 Post subject: Stereo Tool 9.03 BETA
PostPosted: Wed Jul 25, 2018 10:41 am
Stereo Tool 9.03 BETA001
Windows stand alone: https://www.stereotool.com/download/ste ... 03-001.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-001.exe
VST: http://www.stereotool.com/download/vst_ ... 03-001.dll
VST: https://www.stereotool.com/download/vst ... 03-001.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-001.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-001.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-001.exe
Windows libsndfile-1.dll (needed for MicroMPX decoder and command line version, place in same directory): MicroMPX command line enc/dec: https://www.stereotool.com/download/libsndfile-1.dll
ARM32 MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... ETA902-017
ARM32 MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... ETA902-017
ARM32 MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... ETA902-017
ARM64 MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... ETA902-017
ARM64 MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... ETA902-017
ARM64 MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... ETA902-017
  • Improved Stokkemask - output is stricter (closer to the mask), so it has less impact on stereo separation. (*)
  • Memory usage reduced by about 12 MB
    (*) We need a measurement to make sure it's as tight as before. It probably is - but some testing is needed to make sure. I can measure it with my own analyser and with MpxTool, but neither gives a perfectly accurate result. Most importanty, I would like to know if setting the new "New looseness (experimental)" slider to 100% (0% is equal to previous versions) has any effect on compliance. Below 100% there's not really any difference in what I'm measuring, at 100% there is a small difference.
    PLANNED:
  • Stokkemask: Improve further
  • Stokkemask: We don't care about CPU load, try adding more stages
  • Stokkemask: Measure
  • MicroMPX: highs idea BUSY -> Find beta testers
  • Try I/Q Clipper mode BUSY, first part works, highs are coming out slightly too loud, due to LPF? Might be good enough...
  • Test preset that causes buffer to run empty - why? --> Settings issue, maybe add a popup for this situation (buffer is slowly filling up or running empty)...
  • RDS: Support for AF method B
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
  • uMPX decoder: Add multicast subscribe
PostPosted: Wed Jul 25, 2018 12:16 pm
Windows stand alone: -.stereotool.com/download/stereo_tool_standalone_installer_64_BETA903-001.exe
URL link broken? (file appears to be there though!)...
Rossco
PostPosted: Wed Jul 25, 2018 1:32 pm
Ah, oops. I copied it from the 9.02 thread and that build had failed in the last beta there. Fixed now.
PostPosted: Wed Jul 25, 2018 10:54 pm
Stereo Tool 9.03 BETA002
Windows stand alone: https://www.stereotool.com/download/ste ... 03-002.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-002.exe
VST: http://www.stereotool.com/download/vst_ ... 03-002.dll
VST: https://www.stereotool.com/download/vst ... 03-002.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-002.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-002.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-002.exe
  • Stokkemask: Improved further (looks about equally strict, but I can squeeze over 1 dB more anti-phase content through than with 9.02). NOTE: SETTINGS ARE DEFAULTING TO 9.02 BEHAVIOR BECAUSE I DON'T KNOW YET IF THE SIGNAL IS EQUALLY STRICT, AND I DON'T WANT SOMEONE TO GET FINED FOR HAVING STOKKEMASK OVERSHOOTS. To get the new behavior, set "New looseness 1" higher (50% should definitely be safe, I'm not sure about 100%), "New looseness 2" to 30%, and "Side level" to 40.
    PLANNED:
  • Stokkemask: Try I/Q Clipper mode, highs are coming out slightly too loud, due to LPF? Might be good enough... -> Idea doesn't work
  • Stokkemask: We don't care about CPU load, try adding more stages -> No effect
  • Stokkemask: Default back to 50% for safety - that way we don't have to worry about breaking older versions. And we still get 90% of the improvement that way.
  • Include MicroMPX - for real now
  • Add MicroMPX plugin licensing
  • Stokkemask: Measure TOMORROW
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
PostPosted: Thu Jul 26, 2018 9:53 am
Something odd using the latest beta SA:
Enable 'Restart on crashes' under Configuration to automatically restart if this happens again.
EXCEPTION OCCURRED IN ProcessingChain Thread (Exception 0xc0000005 at address 0xf9ec02, read/write=1, r/w location=0x197394). Offset-info: 0xddeda4
EDIT: Tried in Beta 001:
EXCEPTION OCCURRED IN ProcessingChain Thread (Exception 0xc0000005 at address 0xd04762, read/write=1, r/w location=0x197394). Offset-info: 0xb4e314
PostPosted: Thu Jul 26, 2018 10:27 am
Yup, was just reported by someone else as well. Caused by the memory optimizations that I did - should be fixed now, so the next beta shouldn't complain anymore.
PostPosted: Fri Jul 27, 2018 8:20 am
Stereo Tool 9.03 BETA003
Windows stand alone: https://www.stereotool.com/download/ste ... 03-003.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-003.exe
VST: http://www.stereotool.com/download/vst_ ... 03-003.dll
VST: https://www.stereotool.com/download/vst ... 03-003.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-003.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-003.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-003.exe
  • Crash fixed
  • More experimental stokkemask settings added.
    I'm going to meausre things today!
    PLANNED:
  • Cntrct IN
  • Cntrct TM
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
PostPosted: Fri Jul 27, 2018 6:23 pm
Beta 003, still not quite right:
Restart will be attempted.
EXCEPTION OCCURRED IN ProcessingChain Thread (Exception 0xc0000005 at address 0x1c4c5d2, read/write=1, r/w location=0x197394). Offset-info: 0x1a8c334
PostPosted: Fri Jul 27, 2018 10:06 pm
Downloaded DSP 003 and it still shows as 002. Filename is 003.
PostPosted: Sat Jul 28, 2018 9:54 am
Stereo Tool 9.03 BETA004
Windows stand alone: https://www.stereotool.com/download/ste ... 03-004.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-004.exe
VST: http://www.stereotool.com/download/vst_ ... 03-004.dll
VST: https://www.stereotool.com/download/vst ... 03-004.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-004.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-004.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-004.exe
Build 003 wasn't correctly uploaded. Which explains why it still crashed.
  • Removed (moved to Extreme Tweaker for possible future testing) some Stokkemask settings that had a bad effect on compliance. Good settings are 50% / 30% / 40 dB (without the 40 dB it should be fne too, but there's a bigger chance at overshoots at the bottom of the mask. 100% for the first value increases overshoots!!!!! 39 and 38 should be safe as well - but I haven't had time to measure those separately anymore. Anyway in the older versions this value was set to 0....... Setting it higher may cause an audio quality reduction.
  • Crash fixed
    (*) We need a measurement to make sure it's as tight as before. It probably is - but some testing is needed to make sure. I can measure it with my own analyser and with MpxTool, but neither gives a perfectly accurate result. Most importanty, I would like to know if setting the new "New looseness (experimental)" slider to 100% (0% is equal to previous versions) has any effect on compliance. Below 100% there's not really any difference in what I'm measuring, at 100% there is a small difference. ---> RESULT: 100% is bad, keep at 50. Then it's ok.
    PLANNED:
  • Cntrct IN
  • Cntrct TM
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
