Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 97 posts ]  Go to page Previous 1 2 3 4 510 Next
 Post subject: Re: Stereo Tool 7.82
PostPosted: Sun Nov 15, 2015 9:51 pm
Nice new version Hans . Keep up the good work. But there are two main problems . I have hiccups every second or so and the cpu meter shows very very large numbers (in the order of 70% on an i7-4790k for non-fm presets).
For a moment I feared that I had some logging enabled or something like that, but that doesn't appear to be the case. On my laptop I don't see anything strange with the CPU load or hiccups.
Can you send me your settings?
PostPosted: Mon Nov 16, 2015 6:44 am
Just download toliskiller21 absolute pleasure preset and try . I have the same problem with my preset as well but i will send you my preset + some recordings later today (once i finish school).
My radio station
http://amradio.ddns.net
PostPosted: Mon Nov 16, 2015 7:01 pm
Bojcha - Diggy Down: 19.1% - version 7.73 19.4%
Jeroen Platenkamp - Centurion: 27.7% - version 7.73 27.6%
Tolio - Absolute Pleasure: 23.5% - version 7.73 23.0%
(Values vary a bit, but they seem close enough).
CPU: i7 4710 (laptop)
(Absolute Pleasure sounds horrible though, no mids - am I doing something wrong?? - hm you get used to it after a while...)
There is an increase in CPU load that I need to look into, but it's not huge (about 1%).
Edit: Which version did you try? Stand alone, VST, DSP, ???
PostPosted: Mon Nov 16, 2015 7:55 pm
Yeah Hans i know...Im a big fan of high's :P
Well in version 7.73 i dont have this hiccups problem only in 7.82 standalone x64
If you can try this version of my preset i added more mids.
Also i have this problem on every buffer size!
I use i5-2400 @ 3.8 Windows 10 x64
Tolio - Absolute Pleasure v2.sts [74.91 KiB]
Downloaded 297 times
Last edited by toliskiller21 on Mon Nov 16, 2015 10:09 pm, edited 1 time in total.
PostPosted: Mon Nov 16, 2015 9:52 pm
O I didn't try 64 bits. Will try.
Understood @ highs. As I said you get used to it after a while, if you switch from another preset it sounds like something is broken though!
Edit: Similar effect, 23% CPU load in 64 bit stand alone, 7.82. (there is no 7.83 yet!)
PostPosted: Mon Nov 16, 2015 10:08 pm
oops my bad..i pressed the wrong number :P
I have the same problem with the 32 bit version also!
PostPosted: Mon Nov 16, 2015 10:52 pm
Since I don't see it here, can you check in which version this started?
PostPosted: Tue Nov 17, 2015 8:46 am
It started in 7.80
PostPosted: Tue Nov 17, 2015 1:56 pm
It started in 7.80
- Can you also check the CPU load in TaskManager?
- How much did it change (7.73 vs 7.80)?
- Is it only with this preset, or also with all others?
PostPosted: Tue Nov 17, 2015 2:35 pm
Well in 7.73 i have an average of 12% and a max of 15% in task manager.
In 7.82 i have an average of 13% and a max of 16%.
I use a i5-2400 @3.8ghz windows 10 x64
I couldn't find 7.80 cause i deleted the installer.
File comment: 7.82
File comment: 7.73
