So here it is
Release candidate for Warp factor 9 Dutch FM Stokkemask edition , the US and other( German) versions will come in V1
So...what has been done since V0.90?
Cranked up the bass boost ( because a promise makes a promise
Tweaked the Advanced clipper for keeping mids and highs ( because of the higher bass levels )
Adjustments in MB : Filter steepness and "flat tops" lowered Q factors for unity sound in Mid sound en lower highs and flat tops for better bass response
The lower Q factors in the MB makes it possible to lower band coupling so somewhat more open sound ( since they do somewhat the same but in another stage )
More stereo in conjunction with the phase rotation, it gives the overall sound more body.
adjustments in Phase rotation , higher frequency lower smoothing
Notes :
This preset has been made for the Dutch heavy processed radio landscape ( mainly orban sound , stereotool is like grasping some clear air )
I cant use all whistles and bells because of limited CPU power *1
The biggest drawback is that i am not able to use the full smoothing in the stokkemask limiter this fact reduces quality big time , i have to use "faster smoothing" this is bad for clear highs .
( So Hans ...... use the new compiler ASAP
*1
I use an core I5 but i caped it @ 2,7 GHZ ( V core 0.85 V )
This is because of energy savings ( system runs @ 35 watts AC 230 V )
The system runs our whole station
That means :
Playout ( Zara radio )
Stereotool to Elenos transmitter
Encoding for webstreams ( edcast AAC++ and LAME MP3 )
Website inc SQL DB , PHP and apache & FTP server
