"Btw, On all my Processing PCs i have VNC (primary) and TeamViewer as backup.. and i never got problems with that."
I also didn't had any problems with that before, till last week, where teamviewer caused this problem.Normally we have the "standard out" configure to a 'dummy' vac entry...so system sounds (which are disabled), are going to this one..just in case of.
So is teamviewer..but suddenly (since last update somehow), he switched to another VAC , which was being used for the 'live system'. even when he shouldn't generate any sound anyway, it was still generating problems.
Now, this problems was resolved by : 1) not using the teamviewer anymore
(meaning: it is still there as backup,running, but no connections), 2) switching the output again to the 'dummy' vac entry.
"I don't see why you actually need that synchronize option."
don't think that it's needed for me.
"- Good soundcard for ST input (if analog inout is used)"
The soundcard is only used for ouput to FM.
All the rest is VAC (for stream contact-dance.com)
It's actually "audio software" -> VAC1 -> Stereotool standalone to -> 1) vac2 for stream1/stream2 2) soundcard for FM.
(just for your information
I guess nobody will understand me now
