Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Mar 12, 2013 4:18 am
Fixed activation Sidechain EQ, a confusion of "checks", reported to the thread of the current beta version.
SingleBand now works as limiter highs (> 5 KHz approx.), Better control of peaks.
A little more punch in the bass, because now go directly to Clipper.
Comments are welcome! ;)
GAP_Impact_v0.9.zip [9.32 KiB]
Downloaded 430 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Fri Mar 15, 2013 5:34 am
Some changes in the AGC and the MB to beta 54.
Also changed the slope of the crossover.
GAP_Impact_v0.91.zip [9.45 KiB]
Downloaded 383 times
by GAP
PostPosted: Mon Mar 18, 2013 5:10 am
Several changes, same objective of sound. :)
I changed the behavior of the 3 upper bands of MB, passed "Peak" (before RMS) and adjusted times, knee and levels, etc.
Some minor adjustments to the AGC and Clipper driver, now Loudness should not vary too when no bass present.
Adjusted the SB, for a shorter action, only peaks surplus MB.
Small adjustments to BB.
Crossover Slope.
Well and I think nothing more ... :roll:
Made with beta 55
GAP_Impact_v0.92.zip [9.41 KiB]
Downloaded 404 times
by GAP
PostPosted: Fri Mar 22, 2013 5:19 am
Adjusted the use of limiters in the extreme bands, to beta 60.
Some fine adjustments to the MB.
This near being the final version ... ;)
GAP_Impact_v0.93.zip [9.45 KiB]
Downloaded 423 times
by GAP
PostPosted: Mon Mar 25, 2013 8:23 pm
Hans beat me to it ... :)
Final Version! ;)
GAP_Impact_v0.94.zip [9.49 KiB]
Downloaded 544 times
by GAP
PostPosted: Thu Mar 28, 2013 5:35 am
Curious, why set the pre amp to +20db and Post to -.2 db?
PostPosted: Fri Mar 29, 2013 7:12 am
Setting the preamp higher handles very soft inputs. Setting post amp to something less than 0 helps make sure that the total output signal doesn't go above 0. That is more the case with presets that do not use Hard Limit.
PostPosted: Fri Mar 29, 2013 4:15 pm
Brain Thanks for answering.
In my case, I use the Hard Limit which helps not exceed 0 dB and not generate unwanted cropping. Similarly, there is always the possibility of any uncontrolled peak and that is why I use about 0.25 dB of protection. ;)
by GAP
PostPosted: Fri Mar 29, 2013 5:35 pm
Huh, totally wrong. Pre-amp is giving range for AGC and can be said like that, that it hadnles soft imputs, so you will use lower pre-amp or more agressive gate, but it does not have nothing with output. Even next filter, MB, should not have nothing with Pre-amp, since AGC is there to level things up.
PostPosted: Fri Mar 29, 2013 9:49 pm
I interpret that, Brian at no time related to the pre-amp output (but I mention it to the post-amp, which is correct).
And with respect to the Pre-amp, is much more detailed what you say Bojcha, but with less detail Brain said the same. :)
It's just a little clarification, and thank you both for giving explanations of the case. ;)
by GAP
