Post new topic  Reply to topic  [ 12 posts ]  Go to page Previous 1 2
PostPosted: Mon Mar 04, 2019 1:15 pm
My bad! I just discovered that my upload script was missing the .vst3 files - so they were generated on my end, but never uploaded to the server.
I have just uploaded the latest (9.24) versions. NOTE: Due to another very odd bug (probably a ascii/unicode issue), the version number never got updated either, so if you click on the About box you'll still see version 9.02. But it's the latest version. You can verify by checking that the AGC has RMS size and inside-window speed settings (in Advanced mode).
PostPosted: Sun May 12, 2019 3:50 am
I download the most recent version after the changes you made. Still has problems.
The legacy AGC works, the current one does not as it slides the meter to full gain reduction and no audio afterward. The Auto and Bass EQ throws the Exception occurred in GUI error. No audio if they are on. Once off, the audio flows again. MB1 only works in digital. Analog throws the error.
These are settings I've switched on without the aid of presets to aid in further debugging.
The About dialog reads 9.31 (May 2019).
