PostPosted: Thu Aug 11, 2016 10:03 am
I have Raspberry Pi 3 with Cirrus Logic Audio Card 192khz running StereTool but i dont like at all it's sound and i can not get any better sound when i try to fix it....is there any other card that you maybe have try and you are happy for it's sound?
PostPosted: Thu Aug 11, 2016 4:24 pm
We used the same card and were pretty happy with it. Can you explain more about what's wrong with the sound you get? Also, make sure you're really outputting 192kHz.
PostPosted: Thu Aug 11, 2016 8:43 pm
is an empty sound with full of middle frequencies and if i give it bass or tremble from equillizer it become more terrible and always is an empty sound.
It's sure at 192khz because i have stereo and rds on my fm exciter.
PostPosted: Fri Aug 12, 2016 9:59 am
I have measured it on my transmitter and it's frequency response is nearly flat, so this makes no sense. Please measure the response at different frequencies - you might have a broken card (the first one that I ordered was broken too, only generated distortion).
PostPosted: Mon Aug 15, 2016 12:02 pm
You were right! i changed it and all ok :)
PostPosted: Thu Dec 15, 2016 3:08 pm
This $8 sound card works with Raspberry Pi and will do 192k and put out a clean DC flat MPX signal.
Note it has only audio output. I will work with "HIFIBERRY" drivers. It uses TI PCM5102A sound chip.
http://www.ebay.com/itm/ASSEMBLED-PCM51 ... SwLF1X7mVf
