PostPosted: Thu Jun 30, 2016 6:13 pm
I saw this in the EQ section of most of my recent presets, after they are saved. I didn't pay much atention untill I saw it also on Bojcha's Sesame, in the AGC side chain. I'm sure that very narrow and steep cut off is not intentional. Attached find a screen capture
PostPosted: Thu Jun 30, 2016 6:17 pm
Yep.. i didnt do it like that. And i also saw once it happens. Seems not all points are saved or loaded properly.
PostPosted: Thu Jun 30, 2016 9:41 pm
I see it too with this preset.
PostPosted: Thu Jun 30, 2016 10:05 pm
Hmm, looks fine here and the cut isn't in the preset file, I checked that.
