Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 139 40 41 42 43 Next
PostPosted: Wed Oct 12, 2016 8:42 am
Crashes related to VLC input still exist, eg on stream loss, ST needs something inside to isolate from libvlc drops etc..
Urban Junglist
PostPosted: Thu Oct 13, 2016 12:35 am
hi... i installed the new Beta and i have some problems witch exception in processing something ... the 8.0 64bit still works fine thow any ideas ?
PostPosted: Thu Oct 13, 2016 6:21 am
Please post the exact message! There is over 8 MB of code so I cannot guess where it comes from without more info... And which version are you using exactly? I guess 64 bit, but stand alone, DSP, VST, GML, Generic, Carbon Coder?
PostPosted: Sat Oct 15, 2016 5:47 am
I am having problems getting MB 1 to play well in version 8.10 and in 8.11 BETA. Setting density to 0 the bands bury at or near -18 on almost all songs which dulls the sound so badly it cannot be overcome with EQ. My library is normalized to -23 LUFS, player out into ST set to -10. AGC output is -12 with a ratio of 12:1.
I had to revert back to 8.00 because I could never overcome the issue. Anyone else having this problem with MB 1 levels?
PostPosted: Sat Oct 15, 2016 5:39 pm
Bug in the web remote control:
Does not work the slider
PostPosted: Sun Oct 16, 2016 11:10 pm
Confirmed and solved.
Confirmed and solved, drop-down menu's were also broken.
PostPosted: Mon Oct 17, 2016 5:11 am
Windows stand alone: http://www.stereotool.com/download/ster ... r_BETA.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... r_BETA.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... l_BETA.dll
DONE 8.12:
- Problem with Analog compressor on some settings fixed, behavior now same as version 8.00 again.
- Slider in ST web GUI works again.
DONE 8.11:
- Crash when loading Jeroen's Sublime 80's preset (Fixed)
- AGC Window bands different (Fixed)
- Rename Start Ratio back to Ratio, we might not need this after all (?)
- GUI: the small processing time box is always showing 50% usage; on the CPU & latency page correct values are shown though ---> Should show the 1st CPU load from that page.
- GUI: in extreme mode for post-AGC & SB compressors the start ratio box starts on the right edge of the GUI but ends on the left, i.e. you see a part of the box above the peak meters
- SST auto-save settings in the background.
Bugs reported:
- Crash in DSP on first startup. 2nd start was ok.
- Bojcha: 'window' is not implemented well. There is 2 main problems. - Window target is very slow. - Speeds inside window are 0 - should be something like 10x slower then agc speed(s) but not 0.
Later:
- Update website LATER
- CHECK CRASH with VLC - VLC related?? Not seen anymore, later.
- Web interface export preset
- Generate UIDs and use link
- Password for login?
- Run as a service
- Websockets? Later
- Remove inputOldSamplesFixedCopy, should not be needed if I split WAVE from VU meter calculations.
Show MicroMPX block size and quality
PostPosted: Mon Oct 17, 2016 3:06 pm
I hear bad distortions when AGC window is eg 5dB.
Urban Junglist
PostPosted: Mon Oct 17, 2016 6:00 pm
I Also Hear Distortions In the Window Function In AGC Even at 3.4db.
