Hi. I am trying to set up a Juli@ card for FM output, and am following the YT tutorial, but I cannot select anything other than 44.1khz in the Soundcard/Sampling menu. As a matter of fact, it seems like the drop-down menu is greyed out and inactive (it attempts to switch to 192khz for a moment and then reverts back to 44.1).
This happens whether or not I activate Asio.
P.S. and yes, in Control Panel I have changed the settings for this soundcard to 192khz.
Any idea what's going on?
Regards
Christo
PS. OK I figured out the reason - but not the solution. I am using, as INPUT, vlc stream (that's how I am delivering the audio to the transmitter site). Once vlc stream is selected as input, the SampleRate gets disactivated
