PostPosted: Sat Apr 09, 2016 5:17 pm
HELLO TO EVERYONE!
I WANT TO ASK SOMETHING ABOUT ST.
CAN ST OPEN THE LAST PRESET WHEN PC RESTARTS?
THANKS !!
PostPosted: Sun Apr 10, 2016 2:31 pm
normaly ST opens with the last preset when it restarts, but always save your settings(presets) , when you change things and you don't save it as a preset ... then i don't know if ST takes it by a next restart...
PostPosted: Mon Apr 11, 2016 1:38 am
It saves on close, minimise or save. So if you do either of those 3 things it should load with the settings active at that point the next time you start it.
