 Post subject: Input level bars
PostPosted: Tue Feb 23, 2016 2:18 am
I've searched the forums but wasn't able to find an answer for my doubt:
In the LEVELS frame, there are 5 bars: two that change according to the input and in green, two that remain red and always full (at least in my case) and another one, which is white. What do these bars mean ?
Thanks,
Ricardo
 Post subject: Re: Input level bars
PostPosted: Tue Feb 23, 2016 10:20 am
First 2: Input.
Second 2: Output. Should NOT be red though, so your output is too high.
White: MPX level.
PostPosted: Fri Feb 26, 2016 2:14 pm
How can I lower that, Hanz ? I am using only the MPX output, all others are turned down to a minimum.
Thanks !
Ricardo
PostPosted: Fri Feb 26, 2016 2:25 pm
Use the Advanced Clipper and make sure Hard Limit is enabled. That should normally fix it.
PostPosted: Fri Feb 26, 2016 3:00 pm
And it did, indeed. Thanks !
