 Post subject: Marian trace pci code 12
PostPosted: Sun Feb 21, 2016 10:31 pm
I have a hp compaq 8100 intel core i5 3.2ghz
Windows 7 professional 64 bit
With a special pci slot for the marian trace to fit in the low profile desktop, after i have installed the drivers for the marian the next error comes up when the computer is started
DevEnum.registerDeviceNotify: Createfile failed.
Het systeem kan het opgegeven pad niet vinden
Is it a settings problem?
PostPosted: Fri Feb 26, 2016 6:08 am
Did you get this sorted out?
You might try different driver versions and making sure you are installing as an admin?
