 Post subject: Proud 2 go loud
PostPosted: Sat Dec 26, 2015 6:54 pm
New preset since 7.4 ( and since warp factor 9 )
Proud 2 go loud
FM version before the end of the year
P2GL2.sts [76.37 KiB]
Downloaded 1532 times
Test stream OGG
Test stream FLAC
 Post subject: Re: Proud 2 go loud
PostPosted: Sun Dec 27, 2015 2:31 pm
first shot was bad
It's the " i use only headphones @ high volume syndrome " :)
Switched on the spectral balance option in MB2
P2GLV0.2.sts [76.47 KiB]
Downloaded 1252 times
Test stream OGG
Test stream FLAC
PostPosted: Tue Jan 05, 2016 8:16 pm
FM is here
Tested om Elenos ETG 100 Transmitter
P2GL 03 FM STOK.sts [79.69 KiB]
Downloaded 1330 times
Test stream OGG
Test stream FLAC
PostPosted: Sat Oct 22, 2016 5:22 pm
Final version
Web only
I need 2 hook up the transmitter before i can test the preset for FM
Preset is running on my stream ( see sig )
P2GLV10.sts [81.57 KiB]
Downloaded 1179 times
Test stream OGG
Test stream FLAC
PostPosted: Tue Dec 06, 2016 3:44 pm
Minor improvements for now
Next thing 2 do is limit spectral energy per band so that the sum of the frequency bands all driven 2 the max never exceeds 0DB
This will result in better finetunning of the clipper.
I would like 2 mention the FLAC stream , you can hear the output of ST without MP3 artifacts
Happy holiday's !
P2GLV1.1.sts [81.54 KiB]
Downloaded 1115 times
Test stream OGG
Test stream FLAC
PostPosted: Sun Feb 19, 2017 10:49 pm
Updates :
  • MB's are less hard driven
    Adjusted the stereo image so big phase differences do not cause the bass (drums) to drown
    Adjusted the True bass ( 0 DB )
    Did some work on MB1 to get a more stable sound
    Adjusted the MB lower bands release to a tempo of 130 BPM for punch
P2GL1.5.sts [81.42 KiB]
Downloaded 1059 times
Test stream OGG
Test stream FLAC
PostPosted: Fri Mar 03, 2017 3:26 pm
small update
Minor tweaks in stereo image and MB settings
P2GL1.7.sts [81.5 KiB]
Downloaded 1033 times
Test stream OGG
Test stream FLAC
PostPosted: Mon Mar 06, 2017 9:39 pm
V2.0
Faster MB1 settings
Adjusted clipper settings , no more harsh sounding mids and highs
P2GL2.0.sts [81.53 KiB]
Downloaded 1057 times
Test stream OGG
Test stream FLAC
PostPosted: Wed Mar 08, 2017 3:17 pm
Changed AGC settings
> more bass ( sidechain )
> Less mids & highs & slightly more dynamics ( band coupling )
P2GL2.1.sts [83.35 KiB]
Downloaded 1221 times
Test stream OGG
Test stream FLAC
PostPosted: Wed Jul 05, 2017 8:28 pm
another update .
Less steeper MB settings ( except for the 2 first bands )
Changed stereo settings ( for better vinyl sound )
Changed Advanced clipper settings for more bass
Preset runs on mu stream @ the moment
GRTZ
Marthijn
P2GL2.92.sts [85.84 KiB]
Downloaded 1204 times
Test stream OGG
Test stream FLAC
