 Post subject: Stereo Tool 4.20
PostPosted: Thu Oct 15, 2009 12:28 am
:D I have seen version 4.20 in the version history list with some impressive enhancements (below) but when will it be available for download?
2009/10/14 v4.20
Loudness: Added a filter to reduce bass distortion. Bass levels can now be set much higher without getting more distortion than before, or kept at the same level for better sound quality.
Loudness: Added a deep bass boost filter that boost very low (up to about 70 Hz) bass sounds by about 1.5 dB (at 100 Hz the bass is about 0.8 dB softer though).
Low Quality mode: Changed the processing that is used for low quality mode. Quality is much better than before, and the CPU load is reduced.
Low Latency mode: Fixed some issues in the low latency processing. Latency is now approx. 100 ms lower than before, quality is much closer to that of normal latency processing.
Noise gate: Noise reduction can now be set for each frequency band.
Added a number of presets with more bass.
 Post subject: Re: Stereo Tool 4.20
PostPosted: Thu Oct 15, 2009 1:53 am
I'm having some hardware problems, so I have to delay it by a day or two.
You can download the beta if you like here:
viewtopic.php?f=6&t=644&start=100
Enjoy!
PostPosted: Thu Oct 15, 2009 12:30 pm
Thanks ;)
