 Post subject: 4 band
PostPosted: Mon Dec 07, 2015 11:15 pm
I've got a basic 4 band setup with clipper... trying for a semi-transparent sound with exaggerated bass. Open for all feedback and help!
Running this on 3 of our 4 streams...and it is a work in progress.
Country:
http://player.listenlive.co/28161
Rock:
http://player.listenlive.co/43061
Pop:
http://player.listenlive.co/28171
using same attack and release for all four bands. using the multiplier adjustment to try and dial it in.
Don't be shy with criticism!
Sean
4band.sts [83.11 KiB]
Downloaded 485 times
 Post subject: Re: 4 band
PostPosted: Tue Dec 08, 2015 9:10 pm
I liked "7wonders" so much, posted in a thread above that I replace my preset with it on all three streams.
PostPosted: Tue Dec 08, 2015 10:32 pm
Glad you like it.. :)
pop and country stations are way softer (-12dB). Rock is ok :)
PostPosted: Tue Dec 08, 2015 11:08 pm
I'm actually having trouble with the soft audio.
My encoder shows -3db levels on all of my streams yet the country and pop station are considerably quieter. Stereo tool presets are identical! Any thoughts?
