PostPosted: Mon Aug 11, 2008 4:52 pm
Ok see I'm having trouble with this...
I select the FM Hot Europe Stereo preset with the winamp plugin and save that to an STS file and then try to use taht with the command-line but it does NOT process the audio and output like it does with the Winamp plugin.
The Winamp plugin is unregistered and I don't know if that has anything to do with it.
Some help please.
PostPosted: Mon Aug 11, 2008 6:17 pm
Just to make sure: Have you specified the FULL path to the .sts file? You cannot use a local path, you HAVE to use the full path (eg. C:\....\yourfile.sts instead of yourfile.sts or even .\yourfile.sts)
