 Post subject: RDS-TMC support
PostPosted: Mon Sep 21, 2009 12:23 am
Hello,
Is it possible add to stereotool RDS-TMC Support?
 Post subject: Re: RDS-TMC support
PostPosted: Mon Sep 21, 2009 2:29 am
Hello,
Hello avita,
It should definitely be possible - I haven't considered it to be a high priority feature because - as far as I know - only very few stations are transmitting TMC information. Do you have/work for a station that currently broadcasts TMC data, or are you considering adding it?
If so, can you tell me how you (will) receive the TMC information? I assume (and hope) that there's a standard way of transmitting TMC data to radio stations...
