 Post subject: Preset staging
PostPosted: Fri Sep 11, 2015 7:04 pm
Would it be feasible to have an option where you can pre-load a preset and get access to all of the settings, as if it were live and running? Then, after tweaking or saving, etc, you could click a "Go Live" button and then the preset would load and ... well, go live. Would that be helpful to anyone? It seems like a nice, smooth way to be able to work behind the scenes before affecting your output signal.
