 Post subject: Stereo Tool and MagicRDS
PostPosted: Thu Sep 10, 2015 8:21 pm
Hi
Since Stereo Tool now suports UECP Protocol I tought that I could use MagicRDS:http://www.pira.cz/rds/show.asp?art=rds ... r_software for sending RDS over to Stereo Tool for encode but when I input port 4001 into MagicRDS and I enable UECP in Stereo Tool Magic RDS shows that it is connected and in Stereo Tool shows that UECP is Connected but when I want to send some PS data from MagicRDS to Stereo Tool I get Communication Error in MagicRDS
I don't know what is wrong here (I like MagicRDS because it is free)
Is there any free RDS Control software like MagicRDS uvalable?
Thanks for Anwsering and Best Regards
PostPosted: Fri Sep 11, 2015 10:43 pm
Strange. UECP does not have a reply mechanism so I don't know how that program could even detect an error. And it has been tested with at least 2 other programs with which it works fine.
PostPosted: Sat Sep 12, 2015 11:13 am
Magic RDS supports the Pira RDS encoder. That one uses an own protocol, not UECP, so this will not work. Or something has changed?
I use TCP COM Bridge to connect a virtual comport (there is no real comport in that computer) to TCP-IP. Stereo Tool on another computer gets that directly. RDS software I use is RDS-Studio. It's not for free, but there is a demo version around. You can download and test TCP COM Bridge 15 days.
PostPosted: Sat Sep 12, 2015 9:39 pm
Hans which programs did you use to test UECP?
PS: Do you think you could inplement PIRA32 Protocol so we could use MagicRDS as control software (some details are here: http://www.pira.cz/rds/show.asp?art=pira32_development
and here is the manual: http://www.pira.cz/rds/manual.pdf
Here is TCP part of MagicRDS which I tried to use with UECP: http://www.pira.cz/rds/show.asp?art=pir ... via_tcp_ip
